simAddForce equivalent in Remote API
ch46
Post by ch46 » 28 Aug 2014, 04:54
Hello
I'm trying to apply a linear force directly to a respondable body to simulate a boat sliding through the water.
I read about the function simAddForce in the regular API and was trying to find the same function in the Remote API but couldn't find it.
Do you have any suggestions?
Thanks in advance.
Re: simAddForce equivalent in Remote API
Post by coppelia » 28 Aug 2014, 22:55
not all regular API functions have been exported to the remote API. You have 2 possibilities, where the second one is by far the easiest and more recomended:
  • implement a new function in the remote API
  • simply send a signal to a child script, that will then handle the task for you. For instance:
remote API client part:
float forceVectorToApply[3];
simxSetStringSignal(clientId,"vectorToApply",(simxChar*)forceVectorToApply,4*3,simx_opmode_oneshot);
child script part (non-threaded child script):
data=simGetStringSignal("vectorToApply")
if data then
    vector=simUnpackFloats(data)
    simAddForce(shapeHandle,position,vector)
JJEHL
Post by JJEHL » 17 Apr 2015, 10:20
What is the equivalent in python of the following code ?
Maybe, something like :
simxSetStringSignal(number clientID,"vectorToApply",simxPackFloats(array floatValues),simx_opmode_oneshot)
Post by coppelia » 17 Apr 2015, 14:59
Yes, something like that. You'll have to test it though.
