Control a robot arm with a joystick
Tabo
Post by Tabo » 28 Oct 2014, 16:58
Good afternoon. I would like to know how I can do to control a robot arm with a joystick. My OS is windows, and as I have read I need to download a plugin. I would like to bring forth some information from me as I do and where I download this plugin.
Thank you.
Re: Control a robot arm with a joystick
Post by coppelia » 28 Oct 2014, 22:51
the Joystick plugin should already be installed on your Windows V-REP installation (i.e. it is the file v_repExtJoystick.dll). The project files for this plugin are located in programming/windowsOnlyProjects/v_repExtJoystick.
From within a child script you can retrieve information about your joysticks with following 2 functions:
local numberOfJoyticks=simExtJoyGetCount()
local axes,buttons,rotAxes,slider,pov=simExtJoyGetData(deviceIndex)
Tabo
Post by Tabo » 23 Nov 2014, 17:58
Thank you very much . I would like to ask also if you could show a little code as me these functions are used( or any example that you provided ) as the support not find them explained. I would be helpful since I am new to this world.
Post by coppelia » 24 Nov 2014, 10:58
There are only the two functions that I listed in my previous post. The first reads the number of devices attached, the second reads the state of the joystick.
Try something like (from within a non-threaded child script):
	console=simAuxiliaryConsoleOpen("output",20,0)
	local axes,buttons,rotAxes,slider,pov=simExtJoyGetData(0)
	if axes then
		simAuxiliaryConsolePrint(console,"Axis1: "..axes[1]..", axis2: "..axes[2].."\n")
		simAuxiliaryConsolePrint(console,"Could not find a joystick\n")
lshachar
Post by lshachar » 01 Aug 2015, 23:41
I would have not figured out how to use the plugin without your example... I think this should be better documented since I found no other working example for it.
Thank you :)
