Page 2 of 2
Re: ROS Tutorial HELP !
Posted: 13 Jan 2015, 18:13
by Laurie44
pr0t0z wrote:Ok, problem was in:
Nodes connect fine now.
Which file was that?
Thanks!
Posted: 13 Jan 2015, 18:21
by pr0t0z
It was in a file I adapted.
Here is the malfunctioning version:
http://pastebin.com/snVi0CSN
Posted: 09 Feb 2015, 08:58
by sloppy
I've installed V-REP V3.2.0 running on Ubuntu 14.04 64bit, which is meant to work for ROS Indigo, but I still get errors when calling ROS services
rosservice call /vrep/simRosStartSimulation
ERROR: Unable to load type [vrep_common/simRosStartSimulation].
Have you typed 'make' in [vrep_common]
The rest of the tutorial seems to be working; plugin loads, roscd finds what it's supposed to, can see an image from image_view in "rosTopicPublisherAndSubscriber.ttt" and the red bubble rob in "controlTypeExamples.ttt" moves, etc.
Posted: 09 Feb 2015, 09:11
You need to source your environment:
source ~/catkin_ws/devel/setup.bash
(make sure you have the V-REP ROS package in ~/catkin_ws/src/)
Posted: 11 Feb 2015, 09:25
by sloppy
Thanks! That resolved the problem
Posted: 16 Nov 2016, 19:04
by studenTU01
Hello I am using Ubuntu 16.04 and ROS Kinetic in the current V-Rep Version 3.3.2 64bit.
The ROS tutorial - Hydro works for me until the tutorial reaches the rosservice call part.
The Plugins "Ros", "RosInterface" and "RosSkeleton" load succeeded with a roscore running.
I am having the same Problem as sloppy with the rosservice call:
rosservice call vrep/simRosStartSimulation
Have you typed 'make' in [vrep_common]?
I sourced my catkin_ws as explained.
I am not quite sure which "V-REP ROS package" coppelia meant, but I have the self-compiled build version of "vrep_common", "vrep_plugin" and "vrep_ros_interface" (this one I expect to be the "VREP ROS package") in my catkin_ws/src folder.
I really hope that anyone can help me.
Best Regards
Posted: 18 Nov 2016, 09:23
this related to the
old RosPlugin, that you shoudn't use anymore, since it is not that flexible, intuitive and extendable as the
new RosInterface. But what you mention is not in the tutorial anymore (since V3.3.1 I believe)
Posted: 22 Nov 2016, 20:14
by studenTU01
thanks for the reply, is there any "getting started" tutorial for the new RosInterface?
I would just like to have some sort of introduction in how to use the RosInterface.
Best Regards
Posted: 23 Nov 2016, 09:58
There are 2 examples that use the new ROS interface:
- rosInterfaceTopicPublisherAndSubscriber.ttt
- controlTypeExamples.ttt (the red robot, in front is using the RosInterface)
