Mimic Thrust Force Model - Cuboid
DannyYeong
Re: Mimic Thrust Force Model - Cuboid
Post by DannyYeong » 11 May 2015, 17:03
coppelia wrote:You are using a simple 2-state controller. Either you apply a force of X, or a force of Y. It is normal that your control won't be good. You will have to use something more sofisticated, at least a P/PD controller. You will have to try.
How the "5" was determined in the derivative part of the drag control?
   -- str is the derivative paramter of the PD controller
   local str=-5 -- drag (how was it determined?)
   simAddForceAndTorque(propeller,{0,0,-accel[3]*cm})
   local linV,angV=simGetVelocity(propeller)
   local mass=simGetShapeMassAndInertia(propeller)
   local f={linV[1]*mass*str*cm,linV[2]*mass*str*cm,linV[3]*mass*str*cm}
   simAddForceAndTorque(propeller,f)
Post by coppelia » 11 May 2015, 20:02
This is an experimental value, but you could also compute it. It is the drag component.
DannyYeong
Post by DannyYeong » 13 May 2015, 17:12
coppelia wrote:This is an experimental value, but you could also compute it. It is the drag component.
Noted, here's my coding modified for it. It's not a perfect undamped state but it reaches about the target height.
here's the file: http://www.filedropper.com/fullmodel
	body=simGetObjectHandle('Quad_Body')
	pos1={0,0,0.5}
  	pos=simGetObjectPosition(body,-1)
	grav=simGetArrayParameter(sim_arrayparam_gravity)
	mass,inertia=simGetShapeMassAndInertia(body)
	diff=pos1[3]/pos[3]-- >1 shows over extended, <1 shows under extended
		if diff>1 then  -- upward force
		f={0,0,-grav[3]*mass*1.01}  -- to overcome the gravity force
		simAddForceAndTorque(body,f)
		vel=simGetVelocity(body)
		f={0,0,mass*vel[3]*-0.8} -- velocity vector to counter inertia oppositely
		if diff<1 then -- downward force
		f={0,0,-grav[3]*mass*0.99}
Is this workable for future linear movements on XY axis?
