Help to use simSetObjetPosition/simSetObjetMatrix
garrott
Post by garrott » 22 May 2013, 20:30
Hello:
I have a question about de second parameter of both funtions, that is "number relativeToObjectHandle".
How i use it?
Thaks you, and have a nice day.
P.D. Sorry for my english there is not good
Re: Help to use simSetObjetPosition/simSetObjetMatrix
Post by coppelia » 22 May 2013, 20:53
Hello Garrott,
simSetObjectPosition and simSetObjectMatrix and many other commands have that second argument, typically:
simSetObjectPosition(handleOfObject,relativeToObjectHandle,position)
  • If you set relativeToObjectHandle to -1, then the position will be set in an ABSOLUTE manner: the object absolute position will be position.
  • If you set relativeToObjectHandle to the handle of objectY, then the new object position will be at position RELATIVE to the frame of objectY.
This is a convenient way to set the position relative to any other object in the scene without doing complicated transformation. For example, if you want to set the position of objectX same as objectY, you can write:
position={0,0,0}
simSetObjectPosition(handleOfObjectX,handleOfObjectY,position)
garrott
Post by garrott » 23 May 2013, 03:19
coppelia wrote:Hello Garrott,
position={0,0,0}
Thanks for your answer
have a nice day :D
