V-REP and XML
Posted: 23 May 2013, 08:41
by amattag
Hello all,
Does V-REP has support for XML? Can I save and/or load an scene or an object using XML files.
Kind regards,
Antonio Matta.
Re: V-REP and XML
Posted: 23 May 2013, 10:05
Hello Antonia,
V-REP does not directly support XML. Also,
scene and
model files are not XML, but purely binary, in order to offer very fast loading operations.
You can however easily write XML importers/exporters. Have a look at the source code of the
COLLADA importer/exporter, or the
URDF importer plugins, which are located in the
programming folder (
programming/v_repExtCollada and
programming/v_repExtUrdf).
Additionally, you can always install
Lua extension libraries to have the
Lua XML functionality from an
embedded script too.
Re: V-REP and XML
Posted: 24 May 2013, 14:46
by amattag
Thank you! It sounds good to me.
Antonio.
