creating robot via script: respondable mask and motor params
Post by fferri » 13 Oct 2015, 13:54
I want to create my mobile robot (an articulated tracked robot) via script.
The motivation behind this is to avoid repeated operations, for example if I want to change the number of rollers, or change a property common to all rollers, and stuff like this.
I managed to create a kinematic chain of objects and joints, with a script like this:
	this=simGetObjectAssociatedWithScript(sim_handle_self)
	visible_edges=2
	respondable=8
	static=16
	box=simCreatePureShape(0,visible_edges+respondable,{1.2,0.4,0.4},0.6)
	simSetObjectName(box,'object1')
	hybrid=1
	joint=simCreateJoint(sim_joint_revolute_subtype,sim_jointmode_force,0,{0.2,0.45})
	simSetObjectName(joint,'joint1')
	cylinder=simCreatePureShape(2,visible_edges+respondable,{0.6,0.6,0.4},0.6)
	simSetObjectName(cylinder,'object2')
	simSetObjectParent(box,this,false)
	simSetObjectParent(joint,box,false)
	simSetObjectParent(cylinder,joint,false)
	simSetObjectPosition(cylinder,joint,{0,0,0.41})
However I''ve been unable to find some essential functions:
1) how to programmatically change the respondable mask?
2) how to programmatically enable the motor on the joint?
mgianni
Re: creating robot via script: respondable mask and motor pa
Post by mgianni » 13 Oct 2015, 14:06
A description of how to change properties of an object can be found here
http://www.coppeliarobotics.com/helpFil ... terIDs.htm
In particular,
enabling the motor:
simSetObjectIntParameter(joint,2000,1)
changing the respondable mask:
simSetObjectIntParameter(object,3019,mask)
ssj
Re: creating robot via script: respondable mask and motor params
Post by ssj » 14 Apr 2017, 12:31
hey i am new to vrep, dont know much. i am trying for a tracked vehicle robot but dont know to create a chainfor the whhels of my tracked vehicle robot. please help.
ssj
Post by ssj » 14 Apr 2017, 12:37
detailed description is that i have made a robot base with four wheels and attached a laser scanner on its base. i want to control it with ROS for obstacle avoidance using scanner data. chain or track on wheels is left, with the above post i got an idea to use pure shape object and revolute joint for chain but still confused to create it. please help.
Post by coppelia » 18 Apr 2017, 08:16
for the tracked wheels (you mean caterpillars?), you should fake them, since this would otherwise take too much calculation time and also not be as realistic as you can hope for. Have a look at a real tracked vehicle: Models/vehicles/tracked vehicle.ttm. You will notice that it is slow, difficult to control, and its behaviour is not perfect.
On the other hand, you can visually fake a tracked vehicle. Take the example of the demo model Models/components/locomotion and propulsion/caterpillar.ttm. In that case, the underlying simulation model is simply a succession of cylinders to approximate the caterpillar.
Have also a look at this tutorial.
ssj
Post by ssj » 27 Apr 2017, 08:24
Thanks! It was really helpful.
