Lua with zeromq
neostek
Lua with zeromq
Post by neostek » 18 Jan 2016, 19:53
where can i find a tutorial that explain how to extend the lua's functionalties in vrep?
Because i would to add the zeromq lua library bindings and use it inside a child script.
thank you very much for your help
Re: Lua with zeromq
Post by coppelia » 19 Jan 2016, 14:52
normally there is not much to do, you simply drop the various files into V-REP's directory, then, inside of your script that requires the extension library, you write something like:
extensionLib=require("nameOfTheLib")
Have a look how it was done with the luaSocket library (you can find one example in the demo scene socketAndTubeCommunicationExample.ttt)
