Wilsonator
Post
by Wilsonator » 09 Mar 2016, 01:43
Consider a child script in an infinite while loop in the 'sim_childscriptcall_actuation' :
while(1) do
stuff
if(criteria) then
break
This simulation is currently run by a synchronous remote API started by vrep.simxStart(...).
Now take the situation where the remote API calls a stop using:
vrep.simxStopSimulation(clientID, vrep.simx_opmode_oneshot_wait)
vrep.simxFinish(clientID)
Is there a way to detect that the remote API synchronous simulation has called a stop command to Vrep when inside the 'while' loop in 'sim_childscriptcall_actuation'? I tried 'simGetSimulationState' for sim_simulation_advancing_lastbeforestop, sim_simulation_advancing_abouttostop, and sim_simulation_stopped but it didn't seem to detect that Vrep would be stopping that iteration.
Tobias
Post
by Tobias » 09 Mar 2016, 09:01
HI,
I am not sure if I got you right but if you use something like:
while simGetSimulationState()~=sim_simulation_advancing_abouttostop do
the loop should stop with your simulation.
Regards,
Tobi
- Site Admin
Post
by coppelia » 09 Mar 2016, 09:28
If your (infinite) loop is inside of a non-threaded child script, then the server side of the remote API would not be able to handle in-coming commands from the client. Also, the whole simulator will appear frozen.
Wilsonator
Post
by Wilsonator » 15 Mar 2016, 22:34
Is there a way to send a command or value from a remote API to an (infinite) while loop in a non-threaded child script?
I have tried sending signals (ie. simGetIntegerSignal) but they do not seem to update while in the while loop.
Wilsonator
Post
by Wilsonator » 16 Mar 2016, 22:27
I have a simulation running synchronously from a remote API. I need all data and signals to be synchronously shared between a child script and the external script running the external API. Certain signals are being set by the external API before its call to vrep.simxSynchronousTrigger(clientID).
Just to be absolutely sure that all signals have reached V-Rep before the current steps calculations are executed (without having to call a time costly blocking function call such as vrep.simxGetPingTime(clientID) ), I wanted to send the next iteration number to V-Rep and check it compared to the previous iteration number. If the iteration number is incremented by one then the simulation moves forwards. While this synchronization may already theoretically have to happen, this is just my way of putting in a fail-safe bug check to ensure I don't get any funky behavior.
To do this I was running an infinite while loop that would check a string signal for the new iteration number. Of course it was not updating correctly in the while loop. Additionally since this is in a while loop, if the external simulation ends, there will be no increment and the child script gets stuck in the loop. Therefore I also wanted to check to see if the external simulation had called vrep.simxStopSimulation(...). But once again simxGetInMessageInfo() was not working correctly in the loop. If simulation stop command was detected I would 'break' and allow the simulation to end properly. Otherwise it just hangs in the child script.
I do have another solution, where I open a new TCP/IP socket between V-Rep and the Remote API script. Then as the remote API script ends I just send a stop commend through this socket, and in the while loop check for this occurrence and break the loop if it occurs. I was just looking for a cleaner solution using the V-Rep API!
- Site Admin
Post
by coppelia » 17 Mar 2016, 08:28
I think you can also do this with
simxCallScriptFunction, since that call will execute a script function even if simulation is waiting for a trigger. In that function, you can then read other signals, set signals, etc., and also return data if you need. That function can be called in a blocking, one-shot call, but also in a streaming fashion.
