Set Robot Orientation Using CustomUI
aapurnama
Post by aapurnama » 04 Jul 2013, 12:11
How to set Robot Orientation Using CustomUI?
i used simSetObjectOrientation(robot,-1,{0,0,90}). But that Code is not work for all part of robot.
Re: Set Robot Orientation Using CustomUI
Post by coppelia » 04 Jul 2013, 13:00
Not sure about the relationship with the custom UI.
The function to set the orientation of an object with simSetObjectOrientation or simSetObjectQuaternion is correct. If other objects are attached to the object that you are reorienting, they will follow ONLY IF they are static!
If you have a dynamic model you wish to reorient, this represents a physically impossible action (in real-life). So before reorienting them you normally have to dynamically reset them:
If your model objects all share a common base object, do something like this:
-- Init (get the handles of all objects involved):
baseObjectHandle=simGetObjectHandle('theBaseObjectName')
objectHandlesExceptBase={}
toExplore={baseObjectHandle}
while #toExplore>0 do
	obj=table.remove(toExplore,1)
	index=0
	while true do
		h=simGetObjectChild(obj,index)
		index=index+1
		if h==-1 then
			break
			table.insert(objectHandlesExceptBase,h)
			table.insert(toExplore,h)
-- Now reorient the base object:
-- 1. dynamically reset all objects:
simResetDynamicObject(baseObjectHandle)
for i=1,#objectHandlesExceptBase,1 do
	simResetDynamicObject(objectHandlesExceptBase[i])
-- 2. reorient the base object:
simSetObjectOrientation(baseObjectHandle,-1,{0,0,90*math.pi/180})
And never forget: API function expects "regular" units, like meters, kilogramms, seconds, radians. So your 90 should probably be 90*math.pi/180!
aapurnama
Post by aapurnama » 04 Jul 2013, 13:29
