I wonder if there is a way to export a model from vrep to URDF? I tried to export it to collada and then use this tool: http://wiki.ros.org/collada_urdf from ROS to convert it to URDF but I'm getting errors... If not, I guess the only option will be do it by hand...
Best,
Export model to URDF
Re: Export model to URDF
there is currently no direct way of doing this. You can always do something similar as was done in the minimalisticExporter add-on: the source is located in the installation folder, in vrepAddOnFunc_minimalisticExporter.lua.
Hi andrestoga,
What did you ended up doing? I'm having the same issue and so built my own URDF from scratch.
