Unset object property
makbut
Post by makbut » 13 Feb 2017, 12:21
I have created a scene in vrep but I want programmatically to set and unset the scene objects' properties.
Specifically, I want to set the object property to be detectable by laser scanner, so I use the "simSetObjectSpecialProperty" command alongside the "sim_objectspecialproperty_detectable_laser" flag, but after a while I would like the object to not be detectable by the laser, but how can I unset the property?
It is that the scene is big, so if all the objects are detectable, everything is getting really slow, so I try to make detectable only the objects that are around my robot.
makbut
Re: Unset object property
Post by makbut » 13 Feb 2017, 13:40
Update:
I think I found it.
I just use the command simSetObjectSpecialProperty(objectHandle,0) and it works. Whatever property I set before now is unset. However I am not sure if it is a right way to do stuff.
Post by coppelia » 14 Feb 2017, 20:15
if you want to set property sim_objectspecialproperty_detectable_laser for instance, then you should do:
local p=simGetObjectSpecialProperty(objHandle)
p=simBoolOr32(p,sim_objectspecialproperty_detectable_laser)
simSetObjectSpecialProperty(objHandle,p)
to clear it:
p=simBoolOr32(p,sim_objectspecialproperty_detectable_laser)-sim_objectspecialproperty_detectable_laser
But it should not make a difference speed-wise: V-REP will do a 2-pass check, where the first pass is very fast and coarse.
makbut
Post by makbut » 15 Feb 2017, 10:31
Yes, that seems like the right way!
Thanks for the answer!
