Plugin couldn't load dependency libraries
Haster
Post by Haster » 15 Feb 2017, 23:12
I'm trying to extend ExtBubbleRob plugin by my own library, but when I'm loading it an error occurs:
Plugin 'BubbleRob': load failed (could not load). The plugin probably couldn't load dependency libraries. Try 'ldd pluginName.so' for more infos, or simply rebuild the plugin.
Here is my makefile (mostly just modified original one)
CFLAGS = -std=c++14 -I../include -I/usr/local/include/ -Wall -fPIC
LIB = -L/usr/local/lib -lpattern_follower
OS = $(shell uname -s)
ifeq ($(OS), Linux)
    CFLAGS += -D__linux
    EXT = so
    CFLAGS += -D__APPLE__
    EXT = dylib
endif
all:
	@rm -f lib/*.$(EXT)
	@rm -f *.o
	g++ $(CFLAGS) -c  v_repExtBubbleRob.cpp  -o v_repExtBubbleRob.o
	g++ $(CFLAGS) -c ../common/scriptFunctionData.cpp -o scriptFunctionData.o
	g++ $(CFLAGS) -c ../common/scriptFunctionDataItem.cpp -o scriptFunctionDataItem.o
	g++ $(CFLAGS) -c ../common/v_repLib.cpp -o v_repLib.o
	@mkdir -p lib
	g++ scriptFunctionData.o scriptFunctionDataItem.o v_repExtBubbleRob.o v_repLib.o -o lib/libv_repExtBubbleRob.$(EXT)  -lpthread -ldl $(LIB) -shared
clean:
	@rm -f lib/*.$(EXT)
	@rm -f *.o
And ldd ouput:
        linux-vdso.so.1 =>  (0x00007ffc77b91000)
        libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f65ac539000)
        libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f65ac1b1000)
        libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f65abf99000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f65abbd0000)
        /lib64/ld-linux-x86-64.so.2 (0x0000559a22ed1000)
        libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f65ab8c7000)
I think I just overlook something in makefile (I'm not quite good in that stuff), but don't know what exactly.
