I'd like to be able to persistently display the coordinate frame (red,blue,green arrows) of an object (e.g. joints of a robot arm) during simulation. Is this possible? I've tried using the dummy object but it's not the optimum solution. The arrows are too thin so not really visible unless very closeup.
If not already implemented, perhaps an object of type coordinate frame would be a useful feature in the future. The ability to edit the axis and stick it onto another object would be very helpful.
atoz
Display coordinate frame
Re: Display coordinate frame
Hello Atoz,
you can use the frame model located in Models/other/reference frame.ttm. Then, simply attach that frame to the object.
