Using simExtRosInterface_advertiseService
silkjc
Post by silkjc »
Hi VREP community,
Firstly thanks for some great software. I have a question regarding advertising a ROS service, there seems to be very little documentation or usage of simExtRosInterface_advertiseService on the forum.
I wish to set up two services to start and stop publishing a topic.
My question relates to the structure of the required callback function:
stop_service_handle = simExtRosInterface_advertiseService(stopServiceName, 'std_srvs/Empty', 'stop_capture_callback')
function stop_capture_callback(req)
    --simExtROS_disablePublisher('/'..cameraImageTopicName)
    return {true}
After calling the service I get the following:
rosservice call /wrist_cam/stop_capture "{}"
ERROR: service [/wrist_cam/stop_capture] responded with an error:
And from VREP console:
Error: [string -unknown location]:?: ros_srv_callback__std_srvs__Empty: read__std_srvs__EmptyResponse: expected a table (stop_capture_callback)
Obviously it is expecting a table type as the return on the callback function. However I cannot seem to get the required structure for the return. Any help or examples would be awesome! I could not find any example projects that advertise a service.
Re: Using simExtRosInterface_advertiseService
normally you would prepare a service like this:
simExtRosInterface_advertiseService('/testService','std_srvs/Trigger','service_callback')
and have your service routine like that:
function service_callback(msg)
    local reply={}
    reply.success=true
    reply.message="Hello there!"
    return reply
But you are right, it seems there is a problem with the empty message. Even returning an empty table does not work.
silkjc
Post by silkjc »
Thanks for the help, do you have any plans to release a patch or should I be delving into ROSinterfaces plug in code? Does the old ROS plug in have the ability to provide an empty service?
Yes, the git repository will be patched in the next few days.
