Distance from a path
macomber
Post by macomber »
is there a way to get the distance from a robot (or a graph object) to a path?
I would like to get the distance from the graph to the closest point on the path.
The problem I get is that the path is not measurable and it cannot be made so.
I'm trying to compare some line following control algorithms and this would be a really useful metric.
Re: Distance from a path
unfortunately you can't do that. One option you have would be to measure the distance between a collection (e.g. your robot) and a dummy. The dummy would be a point on your path. You will however have to move that dummy along the path with the desired precision if you want to get a somewhat precise answer.
Another option would be to generate a point cloud from your path points. Then measure the distance between that point cloud and the collection, which is much faster than the first option mentioned above.
