Motion Planning with non-threaded child scripts
lari.casteluci
Post by lari.casteluci » 13 Apr 2017, 18:49
I have implemented a motion planning algorithm in a non-threaded child script of my robot. However, I am using simSetJointTargetPosition to move through each point of my path and the robot is not being able perform nicely this way. In other words, is there a way for me to obtain a smoother movement for my robot using the path I have obtained? (changing to a threaded script is not viable)
Re: Motion Planning with non-threaded child scripts
Post by coppelia » 18 Apr 2017, 08:06
yes, but from a non-threaded child script it is a bit more troublesome: given a set of waypoints, you will have to set a new joint target position in each simulation step, by correctly interpolating between the different waypoints. At the same time it is probably a good idea to take into account the current position of the robot, since you are dealing with a dynamic simulation.
