differentiating between red blob and green blob
mmhwmoh
Post by mmhwmoh » 19 Apr 2017, 00:22
Hi there
I have attempted to write my code in a way to try and differentiate which blob is red and green using an epuck where if the blob is green then it will be new xPos1 variable used for the navigation planning which is written this way
            if (proxSensDist[2]+proxSensDist[3]+proxSensDist[4]+proxSensDist[5] ==noDetectionDistance*4)
              and xPos1 >= 0.3 and xPos1 <= 0.7  then
              velLeft=9
              velRight=9
            elseif (proxSensDist[2]+proxSensDist[3]+proxSensDist[4]+proxSensDist[5] ==noDetectionDistance*4)
                and xPos1 < 0.3  then
                velLeft=1
                velRight=5
              and xPos1 > 0.7  then
                velLeft=5
                velRight=1
               velLeft=9
               velRight=-9
which i use it after the checking shown below
i had a condition where i check to see if the epuck is red for example
i define colorCode and xPos1 as within a for loop
           xPos1=t1[2+(1-1)*dataSizePerBlob+3]
            yPos1=t1[2+(1-1)*dataSizePerBlob+4]
            xPos2=t1[2+(2-1)*dataSizePerBlob+3]
            yPos2=t1[2+(2-1)*dataSizePerBlob+4]
            blobSize2=t1[2+(2-1)*dataSizePerBlob+1]
            blobSize3=t1[2+(3-1)*dataSizePerBlob+1]
            blobSize4=t1[2+(4-1)*dataSizePerBlob+1]
            blobSize5=t1[2+(5-1)*dataSizePerBlob+1]
                if (blobBoxDimensions[1]>blobBoxDimensions[2]) then
                    tmp=blobBoxDimensions[1]
                    blobBoxDimensions[1]=blobBoxDimensions[2]
                    blobBoxDimensions[2]=tmp
                    blobOrientation=blobOrientation+math.pi/2
                if (blobSize>0.01) and (xPos1>=0.3) and (xPos1<=0.7) then
                    blobCol1=simGetVisionSensorImage(ePuckCam,resolution[1]*xPos1,resolution[2]*yPos1,1,1)
                    if (blobCol1[1]>blobCol1[2])and(blobCol1[1]>blobCol1[3]) then
                        colorCode1=1
                    if (blobCol1[2]>blobCol1[1])and(blobCol1[2]>blobCol1[3]) then
                        colorCode1=2
                    if (blobCol1[3]>blobCol1[1])and(blobCol1[3]>blobCol1[2]) then
                        colorCode1=3
                elseif (blolbCount == 2) and (blobSize2>0.01) and (xPos2>=0.1) and (xPos2<=0.9) then
                    blobCol2=simGetVisionSensorImage(ePuckCam,resolution[1]*xPos2,resolution[2]*yPos2,1,1)
                    if (blobCol2[1]>blobCol2[2])and(blobCol2[1]>blobCol2[3]) then
                        colorCode2=1
                    if (blobCol2[2]>blobCol2[1])and(blobCol2[2]>blobCol2[3]) then
                        colorCode2=2
                    if (blobCol2[3]>blobCol2[1])and(blobCol2[3]>blobCol2[2]) then
                        colorCode2=3
Then i use the if loop to check whether if the blobs are green or red this is outside of the for loop
if blobCount == 2 and if colorCode == 1 and colorCode ==2 then
                                xPos1 = xPos2
After this however the simulation was still running the same navigation algorithm without taking into consideration of the red and green blobs
many thanks
Re: differentiating between red blob and green blob
Post by coppelia » 19 Apr 2017, 08:31
Hummm, difficult to say, your code probably has some logic problem. Did you try to print the color values to the console to check if detection is correct?
