[Solved] Problem with Collision Checking
francofusco
Post by francofusco » 15 May 2017, 14:56
I am currently working with a dual-arm robot. To validate motions, I need to check collision between some entities. I defined functions that should check the collision state of the robot, but they seems not to work properly.
All my code is contained in three threaded child scripts: one is used for motion validation, the other two for "low level" control of the arms. The idea is that from the first script I move a target (by actuating some joints), while the "controllers" solve IK and move the robot to the target. I am (quite) sure that arms scripts do not contain bugs of any kind. The problem should be in the first one.
Regarding collisions, I defined three collections of objects called "left_arm", "right_arm" and "body". When starting the simulation, all collection handles are grouped inside a table called "collision_pairs" as follow:
collision_pairs = {
    {simGetCollectionHandle('left_arm'),simGetCollectionHandle('right_arm')},
    {simGetCollectionHandle('left_arm'),simGetCollectionHandle('body')},
    {simGetCollectionHandle('body'),simGetCollectionHandle('right_arm')}
(the reason of such choice is that I have other collision groups which I do not want to use; this structure allows me to "quickly" specify which pairs should be considered)
I then defined a function that checks if the robot is in collision:
function isCurrentConfigCollisionFree()
    for i=1,#collision_pairs do
        local coll = simCheckCollision(collision_pairs[i][1], collision_pairs[i][2])
        if coll~=0 then return false end
    return true
Here, the complete script (which moves the target to random configurations):
require "my_ik" -- defines Inverse Kinematics of my robot
simSetThreadSwitchTiming(2) -- Default timing for automatic thread switching
target_joint_handles = {simGetObjectHandle("tj1"),simGetObjectHandle("tj2"),simGetObjectHandle("tj3")}
jhL = { ... } -- stores joint handles of the left arm
jhR = { ... } -- stores joint handles of the right arm
-- get joint positions (listed in a table)
-- jh: table with joint handles
function getConfig(jh)
	local q = {}
	for i=1,#jh do q[i]=simGetJointPosition(jh[i]) end
	return q
-- set joint positions
-- q: table with joint coordinates
function setConfig(jh, q)
	for i=1,#jh do simSetJointPosition(jh[i], q[i]) end
-- check if the configuration of the target is valid
function sampleIsValid(s)
        simSetThreadAutomaticSwitch(false) -- lock switching
        local conf = getConfig(target_joint_handles) -- configuration of the target
        local qL = getConfig(jhL) -- configuration of the left arm
        local qR = getConfig(jhR) -- configuration of the right arm
        local config_free = false
        setConfig(target_joint_handles, s) -- temporarily change configuration of the target
        -- check if there exist inverse kinematic solutions for the arms
        -- the functions ikL and ikR return the IK solutions or nil if the target cannot be reached
        local qinvL = ikL(s)
        local qinvR = ikR(s)
        if (qinvL~=nil) and (qinvR~=nil) then
            -- solution found for both arms: can then check for collision
            setConfig(jhL, qinvL) -- update position of left arm
            setConfig(jhR, qinvR) -- update position of right arm
            config_free = isCurrentConfigCollisionFree()
        setConfig(target_joint_handles, conf) -- reset target's configuration
            setConfig(jhL, qL) -- reset left arm's configuration
            setConfig(jhR, qR) -- reset right arm's configuration
        simSetThreadAutomaticSwitch(true) -- unlock switching
        if (qinvL==nil) or (qinvR==nil) or (config_free==false) then
            return false -- configuration is not valid
            return true -- configuration is valid
-- generate random (valid) configurations of the target
function validTarget()
    local q = {}
    repeat
        for i=1,#target_joint_handles do
            q[i]=Qmax*(2*math.random()-1)
    until (sampleIsValid(q)==true)
    return q
-- move target to random positions and check collision
function threadFunction()
    simSetThreadSwitchTiming(200)
    while simGetSimulationState()~=sim_simulation_advancig_abouttostop do
    	local cfg = validTarget()
        simSetIntegerSignal("follow_target",1) -- tells the other scripts to move the arms
        moveToConfiguration(target_joint_handles, cfg) -- this function makes the target move slowly towards cfg
        simSetIntegerSignal("follow_target",0) -- arms still
        -- check if current configuration is collision free
        assert(sampleIsValid(getConfig(target_joint_handles))==true)
        assert(isCurrentConfigurationCollisionFree()==true)
        simWait(1,true)
pcall(threadFunction) -- execute, ignore errors
-- in the following I do some cleanup
What I would expect is to see the robot moving to collision-free states (eventually colliding between two configuration, but I don't care). Instead, it happens (quite often) that the target configuration is in collision (the assertions do not raise any error, though).
Additional info that may help:
  • Objects of interest are all collidable
  • Joints are all in torque/force mode.
  • All robot shapes are static (and this is why I use simSetJointPosition rather than simSetJointTargetPosition)
  • I added collision detection modules for each collision pair: the collision are correctly evaluated, and the arms become red when in collision
Any idea of what is happening?
Thanks in advance!
Re: Problem with Collision Checking
Post by coppelia » 15 May 2017, 15:57
can you post a simplified scene that illustrates your problem?
francofusco
Post by francofusco » 16 May 2017, 10:15
Shame on me!
Just found I was simply checking collision for the wrong objects. Indeed, I had a "body" collection and a "body_simpl" one. I was using the wrong one...
But thanks anyway!
