Geomagic touch initialization failed
AhmadGazar
Post by AhmadGazar »
Hello, I am trying to connect a geomagic touch with vrep via chai3d plugin . I run chai3d-3.2.0 pioneer example, and it gives me the following error;
Initialization failed (SimExtCHAI3D_start@<unknown plugin>)
Seems like the plugin is loaded correctly, yet the device can not be detected. Any recommendations? Thanks in advance.
Re: Geomagic touch initialization failed
hum, difficult to say. If initialization fails, then it is most probably a driver or device initialization/calibration problem.
AhmadGazar
Actually not, because the the device works perfectly with open haptics and chai3d alone, but the problem exists when I try to connect with vrep.
Looking into the plugin code, the function fails in hapticConnect. In there, it can only fail with following condition:
  // get access to the first available haptic device found
  if (!DeviceHandler->getDevice(device, deviceIndex))
    SceneLock->release();
    return false;
Can't help you further than that.
