Qt-based Custom UI problem
engelrob
Post by engelrob » 19 May 2017, 09:06
Hello!
I'm trying to use the Qt-based Custom UI but I don't know how to run it. The tutorial doesn't say how to execute it.
Any help will be appreciate.
Thanks in advance,
Regards.
francofusco
Re: Qt-based Custom UI problem
Post by francofusco » 19 May 2017, 11:30
Hi!
Basically, you just need to create the definition of the UI using the custom xml syntax. You store such information within a string and you call simExtCustomUI_create(your_xml_description). Then, remeber to call the destroy function if you do not need the UI anymore!
This is a (simple and dumb) example (in a new scene, add a non-threaded script and paste the code Inside it):
function checkCB(ui_handle, item_id, is_checked)
    msg = "Checbox : "
    if is_checked==0 then msg=msg.."not " end
    msg=msg.."checked"
    simAddStatusbarMessage(msg)
function spinboxCB(ui_handle, item_id, new_value)
    simAddStatusbarMessage("Spinbox value : "..new_value)
function buttonCB(ui_handle, item_id)
    simAddStatusbarMessage("Push-button has been clicked")
function radio1CB(ui_handle, item_id)
    simAddStatusbarMessage("You checked the first item")
function radio2CB(ui_handle, item_id)
    simAddStatusbarMessage("You checked the second item")
ui = nil
    xml = [[
        <ui closeable="false" title="MyQtUI" resizable="true">
            <tabs>
            <tab title="First tab">
                <checkbox text=" I am a checkbox" checked="false" onchange="checkCB"/>
                <spinbox prefix="an integer: " minimum="5" maximum="120" step="5" onchange="spinboxCB"/>
                <button text="click me" onclick="buttonCB"/>
                </tab>
            <tab title="Second tab" layout="vbox">
                <group flat="false" layout="hbox">
                    <label text="Select one:"/>
                    <radiobutton text="item 1" checked="true"  onclick="radio1CB"/>
                    <radiobutton text="item 2" checked="false" onclick="radio2CB"/>
                </group>
                <group flat="true" layout="vbox">
                    <label text="Hello, World!"/>
                    <label text="Hello, again!"/>
                </group>
                </tab>
            </tabs>
        </ui>
    ui = simExtCustomUI_create(xml)
    if ui then simExtCustomUI_destroy(ui) end
I am quite a novice with Lua and V-Rep, so maybe someone with more experience will give you better suggestions ;)
Post by coppelia » 20 May 2017, 05:29
Thanks Franco,
yes, have also a look at the code of the various demo scenes or models that use custom UIs. E.g. Models/infrastructure/Floors/infiniteFloor.ttm
