How do I use the water environment
Dragunner
Post by Dragunner »
Just saw on one of your videos that V-rep should be able to model water environment !
How to do that ?
What control do we have on this environment ? (I would like to make some waves of a defined magnitude)
Best regards,
Kévin Exmelin
Re: How do I use the water environment
You can fake the behaviour of water, water currents, etc., by applying auxiliary force/torques to objects. Take the example of model Models/robots/mobile/ACM-R5.ttm : as soon as the robot moves off the platform, it will be in the water. For each robot element, following will be done:
  • A buoyancy force will be calculated and applied
  • A drag force perpendicular to the element longitudinal axis will be computed and applied
In a similar way, you could apply additional forces such as water currents, etc. Waves is probably more difficult to model, but you could try to handle this with auxiliary forces too.
