Scene Object Properties in Radian
I am aware that V-REP API uses radian. But in the scene object properties, joint values are displayed in degrees. Is it possible to set V-REP to display the properties in radians? I checked system/usrset.txt and I couldn't find any flag to set this.
Re: Scene Object Properties in Radian
no, you cannot change that anymore:
- the API is in meters, seconds, Kg and radians, unless otherwise specified.
- the GUI is in meters, seconds, Kg and degrees, unless otherwise specified.
