Screen Sharing
Screen Sharing
Hello, I am fairly new to V-REP and am wanting to get just what I see on my computer screen to a different device, specifically an Android device. The goal is to be able to view my simulation while it is running in order to complete a task. I am curious of what the best way to go about this is, whether V-REP has a similar capability built in or a new app will need to be written to do so. Thank you for your responses in advanced.
Re: Screen Sharing
you can use a third party application probably.
Or you can use a vision sensor. From an external application, you can then access the image that the vision sensor sees via the remote API or ROS.
