Problem with code (Vrep + Matlab)
karabill
Post by karabill » 16 Jun 2017, 00:33
Im new in vrep so be kind with me :) Im doing my bachelor thesis and i have to do some algorithms for path planning. For example, bug 1&2 algorithm, A*(A-star ) and dijkstra. I have understand exactly what i have to do but i dont know the program at all and i cant write the code. We didnt use it in my university so its something new for me.
The connection between vrep and matlab is alright. I use handles for the joints of pioneer_p3dx motors and the front ultrasonic sensor. I managed to start it and stop it after 5sec. What i want to do is when the differential robot find an obstacle to stop. My code is below. WIth that code the robot doesnt move. Any idea?
Matlab code:
vrep=remApi('remoteApi');
vrep.simxFinish(-1);
clientID=vrep.simxStart('127.0.0.1',19999,true,true,5000,5);
if (clientID>-1)
		disp('Connected to remote API server');
        %motors
        [returnCode, left_Motor] = vrep.simxGetObjectHandle(clientID,'Pioneer_p3dx_leftMotor', vrep.simx_opmode_oneshot_wait);%left motor
        [returnCode, right_Motor] = vrep.simxGetObjectHandle(clientID,'Pioneer_p3dx_rightMotor', vrep.simx_opmode_oneshot_wait);%right motor
        %sensors
        [returnCode, front_sensor] = vrep.simxGetObjectHandle(clientID,'Pioneer_p3dx_ultrasonicSensor5', vrep.simx_opmode_oneshot_wait);%fron sensor (5)
        [returnCode,detectionState, detectedPoint,~,~] = vrep.simxReadProximitySensor(clientID, front_sensor, vrep.simx_opmode_streaming);
        %start measuring
        [returnCode] = vrep.simxSetJointTargetVelocity(clientID, left_Motor, 0.1,  vrep.simx_opmode_oneshot_wait);% left motor velocity
        [returnCode] = vrep.simxSetJointTargetVelocity(clientID, right_Motor, 0.1,  vrep.simx_opmode_oneshot_wait);% right motor velocity
        while 1
        [returnCode, detectionState, detectedPoint,~,~] = vrep.simxReadProximitySensor(clientID, front_sensor, vrep.simx_opmode_buffer);% measurement refresh
        disp(norm(detectedPoint))
            if (detectedPoint<2.8)
                [returnCode] = vrep.simxSetJointTargetVelocity(clientID, left_Motor, 0,  vrep.simx_opmode_oneshot_wait);
                [returnCode] = vrep.simxSetJointTargetVelocity(clientID, right_Motor, 0,  vrep.simx_opmode_oneshot_wait);
    disp('Not connected');
vrep.delete()
Vrep scene:
Thank you in advance!
Re: Problem with code (Vrep + Matlab)
Post by coppelia » 16 Jun 2017, 08:11
make sure you have carefully read and understood this page. When you actually try to read data out of the local buffer with simx_opmode_buffer, then you should check the return code to be 0, otherwise the data is not valid.
Also, when you set the joint target velocities, there is no need to use the blocking mode (simx_opmode_blocking, or simx_opmode_oneshot_wait), you should better use simx_opmode_oneshot.
