make object respondable after importing
xelda1988
Post by xelda1988 » 13 Aug 2013, 13:09
Hi
In a childscript I import an object from a .stl file.
I want to make this object respondable in the simulation by using the function simSetObjectSpecialProperty(handle,sim_objectspecialproperty_respondable)
But it seems the system doesn't know the API constant sim_objectspecialproperty_respondable:
My Code:
   shapeHandle=simImportShape(4,"/home/alexander/faceplate.stl",0,0,0.001)
   handle=simGetObjectHandle('Shape')
   simSetObjectPosition(handle,-1,{0,0,1})
   result=simSetObjectSpecialProperty(handle,sim_objectspecialproperty_respondable) -- here the script stops with : One of the function's argument type is not correct. (simSetObjectSpecialProperty)
   print(type(sim_objectspecialproperty_collidable)) -- says Nil
Re: make object respondable after importing
Post by coppelia » 13 Aug 2013, 13:56
there is a mistake in the documentation, thanks for pointing that out!
If you want to make your shape respondable, use following function:
simSetObjectIntParameter(objectHandle,3004,1)
If you call above function during simulation, you might have to call simResetDynamicObject(objectHandle) too.
xelda1988
Post by xelda1988 » 13 Aug 2013, 14:31
the object is now dynamically enabled, but still does not fall down - how can I change this?
*Edit: I solved it with setting simSetObjectIntParameter(handle,3003,0)
