RosInterface plugin setup
JJrobo
Post by JJrobo »
Hi
I'm having trouble getting the RosInterface plugin to work:
- I am using Ubuntu 16.04
- Ros Kinetic
- Downloaded vrep 3.4.0
- I followed the tutorial on the readme here https://github.com/fferri/v_repExtRosInterface and built a .so file
- I put the file into vrep folder
- I launched roscore
- Vrep launches but i see:
Plugin 'RosInterface': loading...
this plugin requires at least V-REP 3.4.0 rev9
Plugin 'RosInterface': load failed (failed initialization).
I can't understand why this happens, please help?
Re: RosInterface plugin setup
this is because your are using the newest RosInterface from the git repository, instead of using the one in your programming/ros_packages folder. If you want to use the newest one from the git repository, then you need to install the beta version of V-REP from here.
