Problem witth RosInterface on Ubuntu 16.04
akhil27
Postby akhil27 » 11 Jul 2017, 08:30
I have ROS Kinetic and got the RosInterface loaded but when I try to run the scene rosInterfaceTopicPublisherAndSubscriber.ttt it lists /image and not /visionSensorData so the command given in the tutorial "rosrun image_view image_view image:=/visionSensorData" doesn't work. Also when I run the scene controlTypeExamples.ttt the red robot doesn't move at all. I can't seem to understand why this is happening. I am new to ROS and v-rep so really need some help.
Thanks in advance,
Akhil
Re: Problem witth RosInterface on Ubuntu 16.04
Postby coppelia » 13 Jul 2017, 12:16
Hello Akhil,
are you sure the RosInterface is loaded? (check the terminal window)
Also, are there any error messages in the lower part of the V-REP window when running those scenes?
akhil27
Postby akhil27 » 13 Jul 2017, 15:53
I am not getting any error message for those scenes.
This is what I get when I start vrep
QSplitter::setCollapsible: Index 0 out of range
Simulator launched.
Plugin 'MeshCalc': loading...
Plugin 'Bwf': loading...
Plugin 'Bwf': load succeeded.
Plugin 'Collada': loading...
Plugin 'CustomUI': loading...
Plugin 'K3': loading...
Plugin 'K3': load succeeded.
Plugin 'Mtb': loading...
Plugin 'Mtb': load succeeded.
Plugin 'OMPL': loading...
Plugin 'OpenMesh': loading...
Plugin 'PovRay': loading...
Plugin 'Qhull': loading...
Plugin 'RRS1': loading...
Plugin 'RosInterface': loading...
Plugin 'RosInterface': load succeeded.
Plugin 'RosSkeleton': loading...
Plugin 'RosSkeleton': load succeeded.
Plugin 'SDF': loading...
Plugin 'SDF': load succeeded.
Plugin 'Urdf-a': loading...
Plugin 'Urdf': loading...
Plugin 'Urdf': load succeeded.
Plugin 'Vision': loading...
Using the 'MeshCalc' plugin.
Checking for an updated V-REP version...
qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method
qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method
Failed checking whether this V-REP version is up-to-date.
Please visit http://www.coppeliarobotics.com to verify
that you are running the last V-REP version.
akhil27
Postby akhil27 » 14 Jul 2017, 08:48
I also tried installing the new beta version of v-rep I saw you suggested on another post and then using the ros packages in v-rep folder to compile the RosInterface. I get warnings but it builds and still gives me a non-moving red bot (https://ibb.co/c2Ngua).
The catkin build gives me
[build] Found '4' packages in 0.0 seconds.
Starting  >>> catkin_tools_prebuild
Finished  <<< catkin_tools_prebuild                    [ 1.9 seconds ]
Starting  >>> ros_bubble_rob2
Starting  >>> vrep_ros_interface
Starting  >>> vrep_skeleton_msg_and_srv
_______________________________________________________________________________
Warnings   << vrep_ros_interface:cmake /home/akhil/quickstart_ws/logs/vrep_ros_interface/build.cmake.000.log
CMake Warning at /opt/ros/kinetic/share/catkin/cmake/catkin_package.cmake:166 (message):
  catkin_package() DEPENDS on 'brics_actuator' but neither
  'brics_actuator_INCLUDE_DIRS' nor 'brics_actuator_LIBRARIES' is defined.
  /opt/ros/kinetic/share/catkin/cmake/catkin_package.cmake:102 (_catkin_package)
  CMakeLists.txt:12 (catkin_package)
  catkin_package() DEPENDS on 'control_msgs' but neither
  'control_msgs_INCLUDE_DIRS' nor 'control_msgs_LIBRARIES' is defined.
  catkin_package() DEPENDS on 'diagnostic_msgs' but neither
  'diagnostic_msgs_INCLUDE_DIRS' nor 'diagnostic_msgs_LIBRARIES' is defined.
  catkin_package() DEPENDS on 'map_msgs' but neither 'map_msgs_INCLUDE_DIRS'
  nor 'map_msgs_LIBRARIES' is defined.
  catkin_package() DEPENDS on 'nav_msgs' but neither 'nav_msgs_INCLUDE_DIRS'
  nor 'nav_msgs_LIBRARIES' is defined.
  catkin_package() DEPENDS on 'pcl_msgs' but neither 'pcl_msgs_INCLUDE_DIRS'
  nor 'pcl_msgs_LIBRARIES' is defined.
  catkin_package() DEPENDS on 'shape_msgs' but neither
  'shape_msgs_INCLUDE_DIRS' nor 'shape_msgs_LIBRARIES' is defined.
  catkin_package() DEPENDS on 'tf2_geometry_msgs' but neither
  'tf2_geometry_msgs_INCLUDE_DIRS' nor 'tf2_geometry_msgs_LIBRARIES' is
  defined.
  catkin_package() DEPENDS on 'tf2_sensor_msgs' but neither
  'tf2_sensor_msgs_INCLUDE_DIRS' nor 'tf2_sensor_msgs_LIBRARIES' is defined.
  catkin_package() DEPENDS on 'trajectory_msgs' but neither
  'trajectory_msgs_INCLUDE_DIRS' nor 'trajectory_msgs_LIBRARIES' is defined.
  catkin_package() DEPENDS on 'visualization_msgs' but neither
  'visualization_msgs_INCLUDE_DIRS' nor 'visualization_msgs_LIBRARIES' is
  defined.
cd /home/akhil/quickstart_ws/build/vrep_ros_interface; catkin build --get-env vrep_ros_interface | catkin env -si  /usr/bin/cmake /home/akhil/quickstart_ws/src/vrep_ros_interface --no-warn-unused-cli -DCATKIN_DEVEL_PREFIX=/home/akhil/quickstart_ws/devel/.private/vrep_ros_interface -DCMAKE_INSTALL_PREFIX=/home/akhil/quickstart_ws/install; cd -
Finished  <<< vrep_skeleton_msg_and_srv                [ 4.1 seconds ]
Starting  >>> vrep_plugin_skeleton
Finished  <<< ros_bubble_rob2                          [ 5.6 seconds ]
Warnings   << vrep_plugin_skeleton:cmake /home/akhil/quickstart_ws/logs/vrep_plugin_skeleton/build.cmake.000.log
  catkin_package() DEPENDS on 'roslib' but neither 'roslib_INCLUDE_DIRS' nor
  'roslib_LIBRARIES' is defined.
  CMakeLists.txt:8 (catkin_package)
cd /home/akhil/quickstart_ws/build/vrep_plugin_skeleton; catkin build --get-env vrep_plugin_skeleton | catkin env -si  /usr/bin/cmake /home/akhil/quickstart_ws/src/vrep_plugin_skeleton --no-warn-unused-cli -DCATKIN_DEVEL_PREFIX=/home/akhil/quickstart_ws/devel/.private/vrep_plugin_skeleton -DCMAKE_INSTALL_PREFIX=/home/akhil/quickstart_ws/install; cd -
Finished  <<< vrep_plugin_skeleton                     [ 5.8 seconds ]
Warnings   << vrep_ros_interface:make /home/akhil/quickstart_ws/logs/vrep_ros_interface/build.make.000.log
Warning at xsl:stylesheet on line 2 column 80 of callbacks.xsl:
  Running an XSLT 10 stylesheet with an XSLT 20 processor
cd /home/akhil/quickstart_ws/build/vrep_ros_interface; catkin build --get-env vrep_ros_interface | catkin env -si  /usr/bin/make --jobserver-fds=6,7 -j; cd -
Finished  <<< vrep_ros_interface                       [ 53.7 seconds ]
[build] Summary: All 5 packages succeeded!
[build]   Ignored:   None.
[build]   Warnings:  2 packages succeeded with warnings.
[build]   Abandoned: None.
[build]   Failed:    None.
[build] Runtime: 55.8 seconds total.
[build] Note: Workspace packages have changed, please re-source setup files to use them.
akhil27
Postby akhil27 » 16 Jul 2017, 08:17
Someone please help me. I need it for a project I need to submit in a few days.
Postby coppelia » 16 Jul 2017, 20:26
If you look at the child script attached to the red robot, you will see that it tries to launch rosBubbleRob2, which is an executable which should be located in the same folder as v_rep.sh. Do you have that executable? And is it launched?
akhil27
Postby akhil27 » 17 Jul 2017, 12:02
There is an executable called rosBubbleRob2 in the V-Rep root folder with vrep.sh. I saw that this error message comes up in the terminal when I run the scene, sorry for not noticing that earlier:
./rosBubbleRob2: symbol lookup error: ./rosBubbleRob2: undefined symbol: _ZN3ros4initERiPPcRKSsj
What could be going wrong? Also, is it okay to ignore the warnings I got with catkin build I posted previously?
Postby coppelia » 17 Jul 2017, 20:16
Did you recompile that executable? If not, try to recompile it and see if it runs.
Probably you haven't installed ROS properly, otherwise you shouldn't have all those warning messages (except for the first message I guess).
akhil27
Postby akhil27 » 18 Jul 2017, 06:13
I recompiled it and it works now. Will reinstall ros and try to get rid of the warnings. Sorry for the trouble.
Return to “General questions”
Who is online
Users browsing this forum: atom, Google [Bot] and 8 guests
