Plotting a variable in a graph (from a ROS node)
mthor13
Post by mthor13 » 21 Jul 2017, 15:58
I want to plot a variable (received from a C++ ROS node) in a graph, but I am having some issues.
I get the following error message:
Lua runtime error: [string "[embScript_47452005.lua] SCRIPT hexapod"]:147: Invalid data stream. (sim.setGraphUserData)
stack traceback:
[C]: in function 'setGraphUserData'
...EP_PRO_EDU_V3_4_0_Linux/lua/hexapod_child_script.lua:147: in function '__scriptCodeToRun__'
/home/mat/V-REP_PRO_EDU_V3_4_0_Linux/lua/sim.lua:19: in function 'include'
[string "[embScript_47452005.lua] SCRIPT hexapod"]:1: in main chunkck:
This is what is currently have:
function CPGOutput_cb(msg)
    data=msg.data
    sim.setGraphUserData(graphHandle, "CPG_output", data)
if (sim_call_type==sim.childscriptcall_initialization) then
    graphHandle=sim.getObjectHandle("Graph")
Is it even possible to plot just a float variable?
SOLUTION:
    data = msg.data
    sim.setStringSignal("CPGOutput_signal",data)
if (sim_call_type==sim.childscriptcall_sensing) then
    signalData=simGetStringSignal("CPGOutput_signal")
    simClearStringSignal("CPGOutput_signal")
    if signalData then
        print(signalData)
        print("\n")
        simSetGraphUserData(graphHandle,"CPGOutput_stream",signalData)
Best Regards,
Mathias Thor
Re: Plotting a variable in a graph (from a ROS node)
Post by coppelia » 25 Jul 2017, 20:45
Hello Mathias,
Are you sure your data stream type is "Various: user-defined"?
Also, make sure to check this link.
Otherwise you can always open a custom user interface window and draw the curve manually (i.e. where you control every aspect of the graph). For that, you can find inspiration in the demo scene customUI.ttt
