BarretHand simTubeOpen failed.
xixiying
Post by xixiying » 26 Jul 2017, 10:09
Hi, I have several BarretHands in one scene. Some of them are ok while some are not. I used the script
communicationTube=simTubeOpen(0,'BarrettGripperState'..simGetNameSuffix(nil),1)
status, rpcnt, wpcnt = simTubeStatus(communicationTube)
It seems that simTubeOpen is not successful with the 'status' of value -1.
Can somebody give me some clues and suggestions?
Thanks a lot!
Re: BarretHand simTubeOpen failed.
Post by coppelia » 28 Jul 2017, 07:06
I suspect you are trying to open a tube with the same dataName several times.
Instead of using tubes, you could also use signals, or directly write a variable in another script with simSetScriptVariable.
Yet another option would be to have objectA write a value into objectB with:
local myVariable={}
myVariable.openGripper=true
simWriteCustomDataBlock(objectB,'myData',simPackTable(myVariable))
and check on a regular base in objectB that value with:
local data=simReadCustomDataBlock(objectB,'myData')
if data then
    local myVariable=simUnpackTable(data)
    if myVariable.openGripper then
