Environment Mapping
Zhenshan Bing
Environment Mapping
Postby Zhenshan Bing » 05 Sep 2017, 21:18
How can I map the environment as fast and well as the official demo does?
I know this demo uses the Hokuyo URG 04LX UG01. But I am wondering if there is a demo scene for more detailed information or algorihtm?
https://www.youtube.com/watch?v=nAWniIe2yU0
Regards and thanks,
Zhenshan
Re: Environment Mapping
Postby coppelia » 06 Sep 2017, 09:08
Hello Zhenshan,
you will have to decide for a sensor first. In case of the Hokuyo, you have a slow and precise version, and a fast and less-precise version.
Then, read the data provided by the sensor and feed them to a point-cloud object for instance.
ssj
Postby ssj » 12 Sep 2017, 05:21
hello
I am also trying to map the environment using rosrun gmapping slam_gmapping but when I simulate my scene in vrep I got this error on ros terminal.
[ WARN] [1505189631.767123764]: Laser has to be mounted planar! Z-coordinate has to be 1 or -1, but gave: -0.07668
[ WARN] [1505189631.862920856]: Laser has to be mounted planar! Z-coordinate has to be 1 or -1, but gave: -0.07663
and this error in vrep
[C]: in function 'simGetJointPosition'
[string "JOINT CTRL CALLBACK BaxterGripper_centerJoi..."]:17: in main chunk
Here is my file
https://drive.google.com/file/d/0B6FmgD ... sp=sharing
Postby coppelia » 12 Sep 2017, 15:14
the reason for the error on V-REP side is because your object that has the joint control callback script attached to it has a name that contains a "#0" suffix. In that script, if getting object handle with:
    a=sim.getObjectHandle('BaxterGripper_closeJoint')
Will actually retrieve the object with the same name suffix as the script has. I.e. it will look for BaxterGripper_closeJoint#0, which doesn't exist.
Make sure to carefully read this page, Access from associated code.
Return to “General questions”
Who is online
Users browsing this forum: Bing [Bot] and 21 guests
