robot not moving straight
ssj
Postby ssj » 12 Sep 2017, 05:59
hello
I am trying to develop a robot but unfortunately at start I got stuck. My robot does not move straight but turns left instead straight and turns right instead backward.
here is the scene https://drive.google.com/open?id=0B6Fmg ... nZla2dDTGM
please help.
Klaus
Re: robot not moving straight
Postby Klaus » 12 Sep 2017, 10:40
The problem is with the wheels.
Your wheels are not of the same size, they are twisted and also not aligned.
If you fix these things it goes in a straight line.
ssj
Postby ssj » 12 Sep 2017, 12:24
hey Klaus
Thank you for pointing. I have adjusted the dimensions and increased the weights of the base. it now works fine and move straight. however I felt that when I increase the velocities of joints i.e., from 10m/s to 50m/s then there is a very very slight tilt towards left. Is it normal?
https://drive.google.com/open?id=0B6Fmg ... 0tvNTJsdnM
Postby coppelia » 12 Sep 2017, 15:28
I cannot observe the left-ish tilting. But your should somewhat increase a little bit the inertia of the wheels, which is too small.
Return to “General questions”
Who is online
Users browsing this forum: Bing [Bot] and 19 guests
