Cant call a childscript function from python api without error
srad
Post by srad » 20 Sep 2017, 22:07
Im a newb to Vrep and was wondering on how to resolve this error
Function didn't produce expected return values, i.e. an int table, a float table, a string table and a buffer string. (simCallScriptFunctionEx on detachObjectFromGripper@RG2)
The function that i wrote is below
detachObjectFromGripper=function()
--use the bottom line to detach the ball
simSetObjectParent(connector,-1,true)
What do i return to get rid of this error
Re: Cant call a childscript function from python api without error
Post by coppelia » 22 Sep 2017, 08:42
Simply return following:
return {},{},{},''
Make sure you have a look at the example in programming/remoteApiBindings/python/python/complexCommandTest.py and the scene that goes with it in scenes/remoteApiCommandServerExample.ttt
