Getting a dummy to follow a path only once
srad
Post by srad »
I defined a path and a dummy, and then used the following command (simFollowPath), to follow the trajectory. How do I get it to only follow the path once. Currently it keeps moving up and back down the path continuously.
Re: Getting a dummy to follow a path only once
in that case you will have to take care of the dummy movement yourself. Have a look at this scene for simple movement generation. For more complex movements, you should use the Reflexxes Motion Library commands, as illustrated in that scene.
