How to make quad target to follow recreated path?
ogyo
Post by ogyo »
Hello :)
I'm having the following issue: When the path is generated for the first time, the green sphere follows it, but when the path is re-created, (and the position of the sphere is set to the start of the path), it simply doesn't move at all.
In addition, I provide a simple scene with the model present: https://drive.google.com/open?id=0B1esb ... HFBVGM2dW8
Thanks.
Best regards.
Re: How to make quad target to follow recreated path?
the scene you posted just has a quadcopter that falls to the ground. Not sure what the intent was.
Also, running the scene, there are errors, you should take care of before trying anything else.
ogyo
Post by ogyo »
Forgot to mention that I'm using Python remote api to control the quad. Could you take a look at the code for the path re-generation and tell me if it's okay? :)
