Error Using simSetShapeColor
Posted: 19 Oct 2017, 12:08
by DavideIng
I have a problem with simSetShapeColor arguments.
The following is the code to get a color string from Matlab:
GotString = simGetStringSignal('ChangeColor')
UnpackedString = simUnpackFloatTable(GotString)
simSetShapeColor(handlePlane,nil,0,UnpackedString)
Vrep return this error:
Lua runtime error: [string "SCRIPT Plane0"]:13: One of the function's argument type is not correct. (simSetShapeColor)
stack traceback:
[C]: in function 'simSetShapeColor'
[string "SCRIPT Plane0"]:13: in main chunk
I know that UnpackedString is a 'table floatingNumber' and simSetShapeColor need as a input argument simFloat* rgbData.
Maybe I have to convert UnpackedString in a right input value for simSetShapeColor.
Any suggestion?
Many thanks
Re: Error Using simSetShapeColor
Posted: 19 Oct 2017, 14:39
The function call looks fine. Make sure that handlePlane is a valid object handle, and that UnpackedString is really a table that contains 3 numbers.
Posted: 19 Oct 2017, 15:21
by DavideIng
I checked but doesn't works again.
Vrep Plane1 (primitive shape) Non-Threaded Child Script:
if(sim_call_type==sim_childscriptcall_initialization) then
simExtRemoteApiStart(20001)
Plane1Handle = simGetObjectHandle('Plane1')
r,initColor=simGetShapeColor(Plane1Handle,nil,0)
SentString = simPackFloatTable(initColor)
--simAddStatusbarMessage('word')
simSetShapeColor(Plane1Handle,nil,0,UnpackedString)
Any other suggestions?
Many thanks
Posted: 22 Oct 2017, 12:54
You need to tell us what exactly is not working. If a function fails, make sure to print out the arguments to verify those are exactly what you expect them to be. If they are not, then the error happened further up in the program.
