GetSimulationTime
DavideIng
GetSimulationTime
Post by DavideIng » 24 Oct 2017, 11:09
I am trying to get the simulation time about vrep scene and send it to Matlab.
I am using the following statements:
Vrep Non-Threaded Child Script:
simExtRemoteApiStart(20001)
handleCuboid = simGetObjectHandle('Cuboid')
simulationTime=simGetSimulationTime()
PackStringTime = simPackFloatTable({simulationTime})
SentStringSignal=simSetStringSignal('PackStringTime',1)
Matlab Statement:
dbstop if error
disp('Program started');
vrep=remApi('remoteApi');
vrep.simxFinish(-1);
clientID=vrep.simxStart('127.0.0.1',20001,true,true,5000,5);
if (clientID>-1)
disp('Connected to remote Api server');
[returnCode,Cuboid]=vrep.simxGetObjectHandle(clientID,'Cuboid',vrep.simx_opmode_blocking);
[returnCode,simulationTime]=vrep.simxGetStringSignal(clientID,'SentStringSignal',vrep.simx_opmode_streaming);
The issue is that the variable simulationTime has the following properties:
Name Size Bytes Class
simulationTime 0x0 0 double
That might means that this variable is not retrieved by the function simxGetStringSignal.
Someone could help me to fix this issue and get the simulation time in Matlab.
Thanks in advance
Davide
Re: GetSimulationTime
Post by coppelia » 25 Oct 2017, 19:15
use simxGetLastCmdTime instead.
