Quadricopter following path problems
ogyo
Post by ogyo » 05 Nov 2017, 22:12
Hi there. I've asked similar questions regarding this topic earlier, but no progress since then. I'm currently working on a project involving a quadcopter moving autonomously in unknown environments with different algorithms.
I'm using Python remote API to generate a list of coordinates that the quad should follow. Then, I'm creating a path which I move the green sphere onto. The problem is this: When the first time the path is generated, the sphere moves along it, but when the path is regenerated, then the sphere just stands there doing nothing.
Video of the problem: https://youtu.be/ef4xdlZkD8w
Main quad script:
-- QUADRICOPTER SCRIPT VREP --
-- CHILDSCRIPT INITIALIZATION CODE:
    -- Make sure we have version 2.4.13 or above (the particles are not supported otherwise)
    simExtRemoteApiStart(19997) -- start RemoteAPI
    v=simGetInt32Parameter(sim_intparam_program_version)
    if (v<20413) then
        simDisplayDialog('Warning','The propeller model is only fully supported from V-REP version 2.4.13 and above.&&nThis simulation will not run as expected!',sim_dlgstyle_ok,false,'',nil,{0.8,0,0,0,0,0})
-- HANDLE AND VREP-SIMULATION CODE:
    -- Detatch the manipulation sphere:
    targetObj=simGetObjectHandle('Quadricopter_target') -- get targetObj handle
    simSetObjectParent(targetObj, -1, true)
    --simSetObjectParent(targetObj,-1,true)
     -- get the targetObj parent
    shouldWeStopCounting = 0
    simulationStep = 0
    d=simGetObjectHandle('Quadricopter_base') -- get Quadricopter_base handle
    target = targetObj
    particlesAreVisible=simGetScriptSimulationParameter(sim_handle_self,'particlesAreVisible')
    simSetScriptSimulationParameter(sim_handle_tree,'particlesAreVisible',tostring(particlesAreVisible))
    simulateParticles=simGetScriptSimulationParameter(sim_handle_self,'simulateParticles')
    simSetScriptSimulationParameter(sim_handle_tree,'simulateParticles',tostring(simulateParticles))
    propellerScripts={-1,-1,-1,-1}
    for i=1,4,1 do
	propellerScripts[i]=simGetScriptHandle('Quadricopter_propeller_respondable'..i)
    heli=simGetObjectAssociatedWithScript(sim_handle_self)
    fakeShadow=simGetScriptSimulationParameter(sim_handle_self,'fakeShadow')
    if (fakeShadow) then
        shadowCont=simAddDrawingObject(sim_drawing_discpoints+sim_drawing_cyclic+sim_drawing_25percenttransparency+sim_drawing_50percenttransparency+sim_drawing_itemsizes,0.2,0,-1,1)
     -- CAMERA INITIALIZATION:
    qc_camera_init = function(inInts,inFloats,inStrings,inBuffer)
        -- Prepare 2 floating views with the camera views:
        floorCam=simGetObjectHandle('Quadricopter_floorCamera')
        frontCam=simGetObjectHandle('Quadricopter_frontCamera')
        floorView=simFloatingViewAdd(0.9,0.9,0.2,0.2,0)
        frontView=simFloatingViewAdd(0.7,0.9,0.2,0.2,0)
        simAdjustView(floorView,floorCam,64)
        simAdjustView(frontView,frontCam,64)
end -- end initialization
-- CHILDSCRIPTCALL CLEANUP:
    simRemoveDrawingObject(shadowCont)
    simFloatingViewRemove(floorView)
    simFloatingViewRemove(frontView)
end -- end cleanup
-- CHILDSCRIPTCALL ACTUATION:
-- Handle and vrep-sim code:
    s=simGetObjectSizeFactor(d)
    pos=simGetObjectPosition(d,-1)
        itemData={pos[1],pos[2],0.002,0,0,1,0.2*s}
        simAddDrawingObjectItem(shadowCont,itemData)
-- Functions:
    qc_Get_vx = function(inInts, inFloats,  inStrings, inBuffer)
        --sp=simGetObjectPosition(targetObj,d)
        m=simGetObjectMatrix(d,-1)
        vx={1,0,0}
        vx=simMultiplyVector(m,vx)
        vy={0,1,0}
        vy=simMultiplyVector(m,vy)
        return {}, vx, {}, ''
    qc_Get_vy = function(inInts, inFloats,  inStrings, inBuffer)
        vx={1,0,0}
        vy={0,1,0}
        return {}, vy, {}, ' '
    qc_Get_Object_Matrix = function(inInts, inFloats,  inStrings, inBuffer)
        local m_string = simPackFloatTable(m)
        simSetStringSignal('mtable',m_string)
    qc_get_absolute_coordinates_sensor = function( inInts, inFloats, inStrings, inBuffer)
        local sensorHandle = 0
        if (inInts[1] == 0) then
            sensorHandle = simGetObjectHandle('Proximity_sensor_back')
        if (inInts[1] == 1) then
            sensorHandle = simGetObjectHandle('Proximity_sensor_front')
        if (inInts[1] == 2) then
            sensorHandle = simGetObjectHandle('Proximity_sensor_left')
        if (inInts[1] == 3) then
            sensorHandle = simGetObjectHandle('Proximity_sensor_right')
        if (inInts[1] == 4) then
            sensorHandle = simGetObjectHandle('Proximity_sensor_up')
        if (inInts[1] == 5) then
            sensorHandle = simGetObjectHandle('Proximity_sensor_down')
        local position = inFloats
        local matrix = simGetObjectMatrix(sensorHandle, -1)
        local absPosition = {1,2,3,0}
        absPosition = simMultiplyVector(matrix, position)
        return inInts ,absPosition, {}, ' '
   qc_get_object_size = function( inInts, inFloats, inStrings, inBuffer)
    local min_x = simGetObjectFloatParameter(inInts[1], sim_objfloatparam_modelbbox_min_x)
    local max_x = simGetObjectFloatParameter(inInts[1], sim_objfloatparam_modelbbox_max_x)
    local min_y = simGetObjectFloatParameter(inInts[1], sim_objfloatparam_modelbbox_min_y)
    local max_y = simGetObjectFloatParameter(inInts[1], sim_objfloatparam_modelbbox_max_y)
    local min_z = simGetObjectFloatParameter(inInts[1], sim_objfloatparam_modelbbox_min_z)
    local max_z = simGetObjectFloatParameter(inInts[1], sim_objfloatparam_modelbbox_max_z)
    a = simGetObjectSizeValues(inInts[1])
    return {min_x, max_x, min_y, max_y, min_z, max_z}, {}, {}, ''
    qc_get_position_on_path = function( inInts, inFloats, inStrings, inBuffer)
        inFloats = simGetPositionOnPath(simGetObjectHandle('Path'), 0.95)
        return inInts, inFloats, {}, ''
   -- Send the desired motor velocities to the 4 rotors:
   qc_propeller_v = function(inInts,particlesTargetVelocities,inStrings,inBuffer)
	for i=1,4,1 do
	    simSetScriptSimulationParameter(propellerScripts[i],'particleVelocity',particlesTargetVelocities[i])
    return {}, {}, {}, ''
end -- end actuation
Green sphere child script:
threadFunction=function()
target=simGetObjectAssociatedWithScript(sim_handle_self)
simulationStep = 0
console = simAuxiliaryConsoleOpen('Debug title', 30, 1)
path = simCreatePath(-1)
generate_path = function(x,y,z, g)
              simCutPathCtrlPoints(path, -1, 0)
              file = io.open("C:\\Users\\path.txt", "r")          --reads csv file
              ctrlPointsBufferTable = {}                          --creates empty buffer table
              i = 0;                                              --csv line counter
              for line in io.lines("C:\\Users\\path.txt") do
              i = i + 1
              numOfdata = i * 16                              --Number of data in csv file(each line contains 11 data)
              for n =1,numOfdata do                               --stores ctrl points' data into the buffer table
              ctrlPointsBufferTable[n] =file:read('*n'); file:read(1)
                simAuxiliaryConsolePrint(console,'\n created path ')
               simInsertPathCtrlPoints(path, 2, 0, i, ctrlPointsBufferTable)
                simAuxiliaryConsolePrint(console,simGetPathLength(path))
              return x,y,z,g
while (simGetSimulationState()~=sim_simulation_advancing_abouttostop) do
        simFollowPath(target, path, 1, 0 , 10, 0.1)
    -- Put your main code here
-- Put some initialization code here:
simSetThreadSwitchTiming(2) -- Default timing for automatic thread switching
-- Here we execute the regular thread code:
res,err=xpcall(threadFunction,function(err) return debug.traceback(err) end)
if not res then
	simAddStatusbarMessage('Lua runtime error: '..err)
-- Put some clean-up code here:
Python code that activates the path regeneration:
    def write_path_to_file(self,coordinates):
        #reset quad target and path
        print "Started writing file"
        [returnCode, targetObj] = vrep.simxGetObjectHandle(self.clientID, 'Quadricopter_target',
                                                           vrep.simx_opmode_blocking)
        [returnCode, qc_handle] = vrep.simxGetObjectHandle(self.clientID, 'Quadricopter', vrep.simx_opmode_blocking)
        [returnCode, qc_position] = vrep.simxGetObjectPosition(self.clientID, qc_handle, -1, vrep.simx_opmode_blocking)
        # vrep.simxSetObjectPosition(self.clientID,targetObj,-1,qc_position, vrep.simx_opmode_oneshot)
        open('path.txt', 'w').close()
        file = open('path.txt', 'w')
        for coordinate in coordinates:
            file.write(str(coordinate[0]) + ',' + str(coordinate[1]) + ',' + str(coordinate[2])
                       + ',0.000000,90.000003,90.000003,1.000000,15,0.500000,0.500000,0.000000,0,0.000000,0.000000,0.000000,0.000000\n')
        file.close()
        vrep.simxSetStringSignal(self.clientID, 'newTrajectory', "true", vrep.simx_opmode_blocking)
        vrep.simxSetStringSignal(self.clientID, 'newTrajectoryResetValues', "true", vrep.simx_opmode_blocking)
        [returnCode, self.pathHandle] = vrep.simxGetObjectHandle(self.clientID, 'Path', vrep.simx_opmode_blocking)
        vrep.simxCallScriptFunction(self.clientID,'Quadricopter_target', vrep.sim_scripttype_childscript,'generate_path',[],[],[],bytearray(), vrep.simx_opmode_blocking)
        print "Finished writing file"
        return True
Could you point me where I'm making the mistake? :)
Thanks upfront :)
Re: Quadricopter following path problems
Post by coppelia » 07 Nov 2017, 09:01
not sure where the mistake is, but I can't help you with algorithms unfortunately, since this is very personal how an algorithm is written, and difficult/time-consuming for another person to look into it. I'm happy to help with V-REP functionality and directed questions.
kemz
Post by kemz » 10 Jul 2019, 21:15
Hello admin,
How do I send forces to Vrep via python using simxsetstringsignal? Please kindly help with this
Post by coppelia » 15 Jul 2019, 06:39
if you have a non-threaded child script, then something like:
function sysCall_actuation()
    local f=sim.getStringSignal('myForce')
    if f then
        local sim.unpackFloatTable(f)
        sim.addForceAndTorque(shapeHandle,force,nil)
You can of course also call a special function in your script via simxCallScriptFunction.
kemz
Post by kemz » 17 Jul 2019, 10:05
Thank you for your help Coppelia, I applied the force, however the quadcopter just shoots right up . How do I make it just hover? I tried applying less force, however this just makes the quadcopter fall. Thank you again for your help
Post by coppelia » 18 Jul 2019, 14:55
Try to practice first with a cube that you make float over the floor. You will have to:
  • add a force that compensates for the weight of the cube
  • add a force that corrects for positional errors (e.g. if you want your cube to be able to move to different heights). A P-controller is probably not going to make it. You'll probably need a PD-controller (where the D-component represents the drag)
kemz
Post by kemz » 25 Jul 2019, 14:53
I got the cube and then the quadcopter to hover by applying forces that compensate for the weight. I can move the quadcopter forward using sim.setObjectFloatParameter(16,3000,velocity[1]). Do I still need to add the PID? And do you have an example code of how to implement PID on the quadcopter?
