Reading and displaying video sensor images using py3 remote API
psychemedia
Post by psychemedia » 13 Nov 2017, 17:43
Any (working) examples out there of how to use python3 and the remote API to:
1) read Baxter vision sensor feeds; (related to this, what is the format of the vision sensor data accessed fro the API?)
2)display single frames taken from the feed (ideally in a Jupyter notebook);
3) display a video feed (ideally in a Jupyter notebook).
This is just a first step on the road to doing image processing on the feed, but I seem (again) to be stumbling at the first hurdle:-(
--tony
Re: Reading and displaying video sensor images using py3 remote API
Post by coppelia » 13 Nov 2017, 22:45
Hello Tony,
here a simple example that streams and displays an image, using openCV:
# -*- coding: utf-8 -*-
Created on Sun Jul 05 15:01:58 2015
@author: ACSECKIN
import vrep
import time
import cv2
import numpy as np
vrep.simxFinish(-1)
clientID = vrep.simxStart('127.0.0.1', 19999, True, True, 5000, 5)
if clientID!=-1:
    print 'Connected to remote API server'
    print 'Vision Sensor object handling'
    res, v1 = vrep.simxGetObjectHandle(clientID, 'vs1', vrep.simx_opmode_oneshot_wait)
    print 'Getting first image'
    err, resolution, image = vrep.simxGetVisionSensorImage(clientID, v1, 0, vrep.simx_opmode_streaming)
    while (vrep.simxGetConnectionId(clientID) != -1):
        err, resolution, image = vrep.simxGetVisionSensorImage(clientID, v1, 0, vrep.simx_opmode_buffer)
        if err == vrep.simx_return_ok:
            print "image OK!!!"
            img = np.array(image,dtype=np.uint8)
            img.resize([resolution[1],resolution[0],3])
            cv2.imshow('image',img)
            if cv2.waitKey(1) & 0xFF == ord('q'):
                break
        elif err == vrep.simx_return_novalue_flag:
            print "no image yet"
            pass
        else:
          print err
else:
  print "Failed to connect to remote API Server"
  vrep.simxFinish(clientID)
cv2.destroyAllWindows()
psychemedia
Post by psychemedia » 14 Nov 2017, 12:35
Lovely - thank you:-)
--tony
