Get orientation and use it for a specific task
DavideIng
Post by DavideIng » 16 Nov 2017, 17:53
I am working with an ePuck, the task is:
When the conditions about the components of ImageTable_rgb (as you can see in the code below) are true, the ePuck has to be rotated of 90 degrees. To do that I am using the following code:
ImageTable_rgb=simGetVisionSensorImage(handleVision,0,0,0)
Orientation = simGetObjectOrientation(ePuck,-1)
if (ImageTable_rgb [1]>0.5) and (ImageTable_rgb [2] < 0.2) and (ImageTable_rgb [3] < 0.2)then
        while (Orientation[1] <= Orientation[1] + 1.57) or (Orientation[1] >= Orientation[1] - 1.57) do
        simSetJointTargetVelocity(leftMotor,-math.pi*0.5)
        simSetJointTargetVelocity(rightMotor,math.pi*0.5)
        simWait(0.5)
It doesn't work.
I am not sure about the following things:
1) I need to know which is the component of the vector Orientation (Euler Angle) refeared to absolute Z axes rotation.
2)I am not sure about the values retrieved by the function simGetObjectOrientation, are they in radians? Because I am considering the while condition in radians but seems to be far to my target.
Any suggestions?
Many thanks
Davide
Re: Get orientation and use it for a specific task
Post by coppelia » 17 Nov 2017, 10:09
Hello Davide,
this is because the e-puck model base has a default orientation of {-pi/2,0,-pi/2} by default (i.e. x-component of the e-puck orientation frame is pointing up, the z-component of e-puck orientation frame is pointing to the forward movement direction). To overcome this you have two options:
1. you can reorient the base of the e-puck to have its reference frame z-component to point up, and y-component to point to the forward direction: select the base of the e-puck, the [Right-click --> edit --> reorient bounding box --> with reference frame of worl]. Once that is done, you can get the desired orientation of the e-puck with:
    local e=simGetObjectOrientation(model,-1)
    -- e[3] is the desired orientation of the e-puck, expressed in radians
2. or you can directly get the desired orientation with following:
    model=simGetObjectAssociatedWithScript(sim_handle_self) -- e-puck model handle
    local m=simGetObjectMatrix(model,-1)
    local m2=simBuildMatrix({0,0,0},{0,90*math.pi/180,90*math.pi/180})
    m=simMultiplyMatrices(m,m2)
    local e=simGetEulerAnglesFromMatrix(m)
DavideIng
Post by DavideIng » 17 Nov 2017, 15:06
Now I get the desired angle but my algorithm is still not working.
The basic idea is:
1) At the begining ''ImageTable_rgb'' is white, afther 10 seconds (simulation time) it became red and the if statement conditions became true
2)The orientation of the ePuck (i.e e[3]) now is around 0 radiant, therefore the while loop conditions is true.
3)Now the ePuck will start to turn until e[3] is equal to pi/2 (i.e 1.57 rad)
4)Ones out of while statement the ePuck has to go straight
I am using to do that the following code:
ImageTable_rgb=simGetVisionSensorImage(Camera,0,0,0)
        local m=simGetObjectMatrix(ePuck,-1)
        if (ImageTable_rgb [1] > 0.5) and (ImageTable_rgb [2] < 0.2) and (ImageTable_rgb [3] < 0.2) then
        while(e[3] < math.pi/2) do
        simSetJointTargetVelocity(leftMotor,-maxVel*0.5)
        simSetJointTargetVelocity(rightMotor,maxVel*0.5)
        simSetJointTargetVelocity(leftMotor,maxVel)
        simSetJointTargetVelocity(rightMotor,maxVel)
The problem is that the algorithm remains in the while loop until infinity.
Any suggestions to fix it?
Many thanks
Post by coppelia » 17 Nov 2017, 15:40
In the while loop, you retrieve the orientation with:
but it should be:
Otherwise you create another local variable e, that disappears when the while loop loops.
DavideIng
Post by DavideIng » 17 Nov 2017, 16:14
Now works!
Many thanks
aburabee3
Post by aburabee3 » 10 Apr 2019, 23:12
I used the above mentioned code to do 90 degree rotation when sensing an object in front, it worked nicely. However on the next object sensing the epuck doesnt rotate again, as the e[3] remains 90, how can we please solve this issue like to reset the e[]3: here is the code:
local m=sim.getObjectMatrix(ePuck,-1)
local m2=sim.buildMatrix({0,0,0},{0,90*math.pi/180,90*math.pi/180})
m=sim.multiplyMatrices(m,m2)
local e=sim.getEulerAnglesFromMatrix(m)
print (e[3])
if ((proxSensDist[2] or proxSensDist[3] or proxSensDist[4] or proxSensDist[5]) < noDetectionDistance) then
sim.setJointTargetVelocity(leftMotor,-maxVel*0.5)
sim.setJointTargetVelocity(rightMotor,maxVel*0.5)
print (e[3])
sim.setJointTargetVelocity(leftMotor,maxVel)
sim.setJointTargetVelocity(rightMotor,maxVel)
