The TIMER problem
Sanchez2k
The TIMER problem
Post by Sanchez2k » 03 Dec 2017, 21:06
Hi !
If I start simulation then the robot immediately begins to work, but I need to put time that the robot starts later enough this time. How can I do the timer or any sensor algoritm? What do you recommend? Thank you.
Re: The TIMER problem
Post by coppelia » 05 Dec 2017, 21:39
this depends whether you are using a threaded or non-threaded child script. With threaded child scripts, you can simply use a simWait.
With a non-threaded child script, you can use a counter or check the time and compare it with the start time, using simGetSimulationTime.
Sanchez2k
Post by Sanchez2k » 06 Dec 2017, 18:32
Can you show a script example? Thank you :)
