Robot disappears when stopping the simulation - Python API
neveryoubetray
Post by neveryoubetray » 06 Dec 2017, 23:26
Hey guys,
I'm having a problem when trying to reset the model using simxStopSimulation. If V-REP is opened manually, a robot dragged in, the simulation ran and stopped, the robot returns to the original position. But all efforts to do this using a python script has resulted in the robot disappearing, the simxStartSimulation will then run the simulation without a robot and the position of the robot returns zeros.
I have tried my own model, and a supplied NAO model with the same results. I also have tried starting V-REP externally first, then loading the model from the python script. The problem seems to occur even if I try to manually click the stop button once the model has been loaded from the script.
I'll add as well that I have tried loading a scene instead of a model, the scene loads but the robot isn't in it from the start.
The folder containing the script also has vrep.py, vrepConst.py and remoteAPI.so (I am using Ubuntu 16.04).
Am I missing something in my implementation?
Thanks for your time!
def run():
    path = "/home/brendan/V-REP_PRO_EDU_V3_4_0_Linux/"
    vrep_path = path + 'vrep.sh'
    args = [vrep_path]
    inst = sp.Popen(args)
    time.sleep(5)
    v.simxFinish(-1) # just in case, close all opened connections
    clientID=v.simxStart('127.0.0.1',19997,True,True,5000,5) # Connect to V-REP
    if clientID!=-1:
        print ('Connected to remote API server')
        v.simxSynchronous(clientID,True)
        v.simxStartSimulation(clientID,v.simx_opmode_blocking)
        model_path = '/home/brendan/Dropbox/robot/mybot_ws/src/vrep/scripts/NAO.ttm'
        # scene_path = '/home/brendan/Dropbox/robot/mybot_ws/src/vrep/scripts/nao_scene.ttt'
        _, robot_handle = v.simxLoadModel(clientID, model_path, 0, v.simx_opmode_blocking)
        # robot_handle = v.simxLoadScene(clientID, model_path, 0, v.simx_opmode_blocking)
        print(robot_handle)
        for i in range(1000):
            _, xyz = v.simxGetObjectPosition(clientID, robot_handle, -1, # retrieve absolute, not relative, position
            print(xyz)
            if i%100 == 0 and i != 0:
                print("fallen over")
                v.simxStopSimulation(clientID, v.simx_opmode_blocking)
                v.simxGetPingTime(clientID)
                time.sleep(5)
            v.simxSynchronousTrigger(clientID)
    v.simxFinish(clientID)
    print('connection closed...')
Re: Robot disappears when stopping the simulation - Python API
Post by coppelia » 09 Dec 2017, 18:03
by default, objects will be reset to their original position/orientation at the end of a simulation. By default too, objects added to the simulation while simulation is running, will be removed at the end of a simulation.
You can change the default behaviour in the simulation properties. Or you can add the object before simulation is started.
neveryoubetray
Post by neveryoubetray » 11 Dec 2017, 00:18
Legend! Thank you.
