Strange behaviour among PCs and in the same PC
martin
Post by martin » 07 Dec 2017, 18:27
A colleage and me are working on a project and we found a strange behaviour on VREP.
We are running a mobile robot, we use revolute joints as motors. We control our mobile robot by the external Python API. We use the "simxSetJointTargetVelocity" function for moving the robot.
In this context, we found a strange behaviour:
Both of us use laptops and we can observe a different behaviour when the laptop is connected to the wall or if it is using the battery laptop. In this case, the velocity that we can observe and meassure while the laptop uses its battery is approximately a half of the velocity than we can observe if the computer is conected with its power supply.
Furthermore, the same scene, the same code and the same IDE performs different in her laptop than in mine. Again, approximately the half of velocity in one case then the other (perhaps this may be should to this: viewtopic.php?f=9&t=7044)
Any idea what can be happening?
Regards!
Re: Strange behaviour among PCs and in the same PC
Post by coppelia » 10 Dec 2017, 21:47
When you say that the observed velocity is half... does that mean the robot appears to take twice as long to reach a specific location? or does that mean that the displayed simulation time is double, when reaching that same location?
martin
Post by martin » 12 Dec 2017, 17:31
What It happen is:
I'm using a Python external API and I'm working wiht Python functions. The pseudocode I'm using is the following:
for n in range (0, 4):
    returnCode, posicion_inicial = vrep.simxGetObjectPosition(clientID, carcasaHandler, -1, vrep.simx_opmode_buffer)
    targetVelocity = [-vel_izq, -vel_der]
    returnCode = vrep.simxSetJointTargetVelocity(clientID, leftMotorHandler, targetVelocity[0], vrep.simx_opmode_streaming)
    returnCode = vrep.simxSetJointTargetVelocity(clientID, rightMotorHandler, targetVelocity[1], vrep.simx_opmode_streaming)
    time.sleep(t)
    targetVelocity02 = [0, 0]
    returnCode = vrep.simxSetJointTargetVelocity(clientID, leftMotorHandler, targetVelocity02[0],vrep.simx_opmode_streaming)
    returnCode = vrep.simxSetJointTargetVelocity(clientID, rightMotorHandler, targetVelocity02[1],vrep.simx_opmode_streaming)
    time.sleep(2)
    returnCode,end_position = vrep.simxGetObjectPosition(clientID,carcasaHandler,-1,vrep.simx_opmode_buffer)
    array_distancia[n] = posicion_inicial[0] - end_position[0]
    print "Distance:", array_distancia[n]
the same code, tested in both PC works different:
In my PC array_distancia[n] ussually is 0.48 (approx.)
In my colleage PC array_distancia[n] ussually is 0.62 (approx.)
It seems that it the same period of time "time.sleep(t)" with t=4 in our case, the distance displaced by the robot is different in both cases. And apparently, one can see that the mobile robot moves faster in that PC which moves longest distance.
And the point is, if we make changes in the code, the results change, but they are never equal in both computers.
The simulation parameters are the same in both cases and are those predefined by the VREP. (dt=50ms)
Regards.
Post by coppelia » 17 Dec 2017, 17:40
Do you have the real-time mode enabled during simulation? You can toggle it with a toolbar button, or via the simulation settings.
martin
Post by martin » 18 Dec 2017, 12:14
Hello Coppelia,
We do not have the real time mode enable. Our configurations settings are those that came from default. I supposse that if the computers are different, a simple program as I have post (without any type of calculation) would work similar in both PC in non-synchronous mode.
Regards!
Post by coppelia » 22 Dec 2017, 16:46
No, because simulation time is not equal to real-time! By default, in V-REP, a simulation will run as fast as possible (why run it real-time, if you can get the simulation results much faster (in some situations)). So if your machine is faster than that of your friend, everything will move and appear faster. That is, unless you enable the real-time mode as explained in my previous post.
