ROS indigo + V-REP
aefka
ROS indigo + V-REP
Post by aefka » 11 Dec 2017, 23:03
Hi
On studies I got a exercise to connect V-REP with ROS. In V-REP I have basic model Ackermann from "model browser". I want to control this model by ROS on RPi. I have got install ROS INDIGO on RPi and PC(Ubuntu 14.04). When I turn on V-REP, plugins RosInterface and RosSkeleton are loaded.
I have no idea, what I should do next. I want to control vehicle by arrows on keyboard.
Thanks for time :)
Re: ROS indigo + V-REP
Post by coppelia » 17 Dec 2017, 17:36
you can get inspiration from this scene: rosInterfaceTopicPublisherAndSubscriber.ttt
and that model: Models/examples/simple Ackermann steering.ttm
aefka
Post by aefka » 29 Dec 2017, 15:57
First, I try to do this: https://www.youtube.com/watch?v=nLKLu4Hw_mU
When I turn on simulation appears error:
Lua runtime error: [string "SCRIPT RobotBase"]:30: unsupported message type. please edit and recompile ROS plugin (simExtRosInterface_advertise @ 'RosInterface' plugin)
stack traceback:
	[C]: in function 'simExtRosInterface_advertise'
	[string "SCRIPT RobotBase"]:30: in main chunk
When I start V-REP, Plugin RosInterface is loading succesed.
I have no idea why is error about RosPlugin.
30 line of code:
 sensorPub=simExtRosInterface_advertise('/frontUS','std_msg::Float32')
All code:
function callback_MotorVelocity(msg)
    simSetJointTargetVelocity(hLeftMotor,msg.linear.x)
    simSetJointTargetVelocity(hRightMotor,msg.linear.y)
    simAddStatusbarMessage(string.format("Vl:%f Vr:%f", msg.linear.x, msg.linear.y))
    hLeftMotor = simGetObjectHandle("LeftMotor")
    hRighrMotor = simGetObjectHandle("RightMotor")
    hFrontUS = simGetObjectHandle("FrontUS")
    local moduleName=0
    local moduleVersion=0
    local index=0
    local pluginNotFound=true
    while moduleName do
        moduleName,moduleVersion=simGetModuleName(index)
        if (moduleName=='RosInterface') then
            pluginNotFound=false
        index=index+1
    if (pluginNotFound) then
    simAddStatusbarMessage('The RosInterface was not found. SImulation will not run properly!')
    simTimePub=simExtRosInterface_advertise('/simTime','std_msg::Float32')
    motorSub=simExtRosInterface_advertise('/cmd_vel','geometry_msgs::Twist','callback_MotorVelocity')
    simAddStatusbarMessage('Simulation initialized')
    if not pluginNotFound then
        result,distance=simReadProximitySensor(hFrontUS)
        if(distance~=nil) then
            simExtRosInterface_publish(sensorPub,{data=distance})
            simExtRosInterface_publish(simTimePub,{data=simGetSimulationTime()})
    if RosInterfacePresent then
        simExtRosInterface_shutdownPublisher(sensorPub)
        simExtRosInterface_shutdownPublisher(simTimePub)
        simExtRosInterface_shutdownSubscriber(motorsSub)
Can someone help me?
Billie1123
Post by Billie1123 » 29 Dec 2017, 18:08
Try
 sensorPub=simExtRosInterface_advertise('/frontUS','std_msg/Float32')
Regards
aefka
Post by aefka » 29 Dec 2017, 18:36
Unfortunately, it didn't help :/
Regards
Billie1123
Post by Billie1123 » 29 Dec 2017, 20:32
There is another misspelling I had not seen. Try
 sensorPub=simExtRosInterface_advertise('/frontUS','std_msgs/Float32')
I am positive it will work (or at least, you'll get a different error :D).
Bear in mind:
- The package name is std_msgs
- Packages and message types are separated by / , not :: using the rosInterface plugin.
Regards
aefka
Post by aefka » 29 Dec 2017, 21:05
ooo, it works, but in 32 line also error appear:
Lua runtime error: [string "SCRIPT RobotBase"]:32: read in arg 3 (queueSize): expected int (simExtRosInterface_advertise @ 'RosInterface' plugin)
stack traceback:
	[string "SCRIPT RobotBase"]:32: in main chunk
Line 32:
motorSub=simExtRosInterface_advertise('/cmd_vel','geometry_msgs/Twist','callback_MotorVelocity')
callback_MotorVelocity is function defined at the beginning of the code
Billie1123
Post by Billie1123 » 29 Dec 2017, 22:46
You are using the advertise plugin constructor when you actually want a subscriber. Use simExtRosInterface_subscribe instead.
I suggest you take a better look at the aforementioned scene by coppelia (rosInterfaceTopicPublisherAndSubscriber.ttt) and to the child script of the robot rosInterfaceControlledBubbleRob from controlTypeExamples.ttt
I personally found those two scenes very handy when I first started to communicate between V-REP and ROS.
Regards
