V-REP doesn't see outputs from ROS
mamagosia
Post by mamagosia »
I've got a problem with sending outputs from ROS to V-REP.
Rostopic shows me there are right values of variables that I want to change in V-REP, but in the simulator nothing is changing.
In rqt_graph and from command roswtf I've got:
https://drive.google.com/file/d/1iasqW8 ... _F8kl/view
This is my code from LUA script:
simExtROS_enableSubscriber("/vrep/cmd_vel",1,simros_strmcmd_set_twist_command,-1,-1,'Command_Twist_Quad')
What I should do?
mamagosia
Re: V-REP doesn't see outputs from ROS
Post by mamagosia »
(I edited my post above with image)
it seems you are using the old ROS plugin for V-REP. Please use instead the newer and more flexible ROS interface.
