Components stick together
VincentAVV
Post by VincentAVV » 23 Aug 2013, 10:53
I have some problems with some packages that stick together during the simulation.
I tried several setting but the packages still stick together some times.
Here can you see how they stick together. https://www.dropbox.com/s/d9xbhz5zwcrx85i/Test.avi
How can I solve this?
Vincent
Re: Components stick together
Post by coppelia » 23 Aug 2013, 11:00
Hello Vincent,
we need much more information, such as: what engine are you using, what shape types are sticking together, etc. The easiest would be to post your scene file.
But at first glance I suspect that you are not using pure shapes. Make sure you have understood the first 3 design considerations listed here.
VincentAVV
Post by VincentAVV » 26 Aug 2013, 06:27
I've used convex shapes, but changed it to pure shapes.
The problem is solved now.
Thanks a lot.
