How to calculate the coordinate by depth, resolution and perspective angle
Zhuang
Post by Zhuang » 07 Feb 2018, 09:05
Hi, coppelia
Recently, I try to use depth sensor to calculate a world position of a pixel. I see the sensor is different from real camera. I am not sure if the method that is used to calculate a position by perspective angel and depth is right.
    camXHalfAngle = camXAngleInDegrees * 0.5 * math.pi/180
    camYHalfAngle = math.atan(math.tan(camXAngleInDegrees*0.5* camYResolution/camXResolution))*math.pi/180
    nearClippingPlane = 0.01
    depthAmplitude = 3.5
    xAngle = ((320-u+0.5)/320)*camXHalfAngle
    yAngle = ((240-v+0.5)/240)*camYHalfAngle
    depthValue = image_depth[v-1][u-1]  # u and v are the coordinate of the pixel. because the depth is turned so [v-1]#[u-1]
    zCoord = nearClippingPlane+depthAmplitude * depthValue
    xCoord = math.tan(xAngle) * zCoord
    yCoord = math.tan(yAngle) * zCoord
    pixels_coordinare_kinetic = np.mat([[xCoord],[yCoord],[zCoord],[1]], np.float)
cheers,
zhuang
Re: How to calculate the coordinate by depth, resolution and perspective angle
Post by coppelia » 08 Feb 2018, 07:57
Hello Zhuang,
did you have a look at the model Models/components/sensors/Blob to 3D position.ttm available since release V3.5.0?
