path planning
WZJ
path planning
Post by WZJ » 12 Feb 2018, 08:40
I have a question when i use the dummy for parent. Just like the example of practicalPathPlanningDemo.ttt , I put my robot under the start dummy. But when my robot is moving, the dummy do not follow. I have tried many times and check all the possible possibility problem, but it doesn't work. Can you help me?
Cheers.
WZJ
Re: path planning
Post by WZJ » 12 Feb 2018, 08:47
and this is my module.
https://github.com/wzjscut/my_Vrep
Re: path planning
Post by fferri » 12 Feb 2018, 11:17
Why do you need that?
You can have a dummy move with the robot by placing another dummy as child of the robot.
Anyway, path planning functionality is deprecated. You should consider using the OMPL plugin.
WZJ
Re: path planning
Post by WZJ » 12 Feb 2018, 12:07
well , when i use OMPL to plan the path. the same problem happened. dummy is the parent. and my robot cannot follow the dummy to run.
