API Constants not working with simxSetModelProperty
Rex
Post by Rex » 19 Feb 2018, 10:20
I'm encountering issues when trying to set a model to have non-dynamic property using the C++ Remote API:
When I try to use the API constant 'sim.modelproperty_not_dynamic', the compiler throws: ‘sim’ was not declared in this scope
Here's the code I'm using
//remove robot from physics engine
int prop;
simxGetModelProperty(clientID, objectHandle, &prop, simx_opmode_blocking);
simxSetModelProperty(clientID, objectHandle, prop|sim.modelproperty_not_dynamic, simx_opmode_oneshot);
//Set Object Position
const float position[] = {2,2,0};
int simxSetObjectPosition(clientID, objectHandle, -1,  position, simx_opmode_oneshot)
//Place robot back into physics engine
SetModelProperty(ModelHandleIDs.back(), prop);
The code compiles fine and doesn't encounter runtime errors if the parameters changed to:
simxSetModelProperty(clientID, objectHandle, prop, simx_opmode_oneshot);
I have made the includes mentioned in http://www.coppeliarobotics.com/helpFil ... ntSide.htm in the makefile, and have no issues using remote API functions like simxLoadModel, simxSetObjectPosition etc.
Is there a different set of API constants for the Remote API? I'm using the constants listed on this page: http://www.coppeliarobotics.com/helpFil ... Properties
It was linked from the simxGetModelProperty documentation.
Thanks in advance!
Re: API Constants not working with simxSetModelProperty
Post by fferri » 19 Feb 2018, 13:48
In C/C++ you use sim_modelproperty_not_dynamic and not sim.modelproperty_not_dynamic.
The latter is used in V-REP Lua scripts only.
Rex
Post by Rex » 19 Feb 2018, 17:33
I see! Thanks for the help!
