Serial not reading entire line
jlouis2k4
Post by jlouis2k4 » 21 Feb 2018, 22:27
Hello there,
I am sending v-rep a line of data, but it is only being read in chunks when I use simSerialRead. The differnece in input and output data are shown in the link below:
https://imgur.com/a/HyOXN
The code used to read and print the serial data is provided below:
    countReadChar=simSerialCheck(serial)
    if countReadChar>0 then
        str=simSerialRead(serial,5000,false,'\n',0)
        simAddStatusbarMessage(str)
Please let me know if I need to reconstruct the data myself or if there is an easier inbuilt way to do that.
Thanks!
Re: Serial not reading entire line
Post by coppelia » 22 Feb 2018, 07:50
yes, you will have to assemble the chuncks yourself, or at least wait until the serial buffer has enough data to read and only read as many chars as one line contains.
If you operate from a threaded child script, you could read in a blocking fashion, and use * as the closing string.
